VAFC AND TPS QUESTION!?????
Old Dec 1, 2005 | 08:53 AM
DeDonDeRosa's Avatar
Default VAFC AND TPS QUESTION!?????
MY vafc only reads like 96-97 % when the throttle is floored when driving and even when the car is off with the key on acc. ?? idk what is it ???? is my TPS going bad or something??? it does not read 100% for some reason
helpe me out please my vac at idle is like -17 about that... idk
Old Dec 1, 2005 | 09:34 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: VAFC AND TPS QUESTION!????? (DeDonDeRosa)
It's most likely caused by your cable not being tight enough. Mine also showed around a 98-99%.
In the engine bay, use your hand and open the throttle plate as much as it can go. Then have a look at the AFC reading and see what it is. If it's 100% then the cable is the reason.
Old Dec 1, 2005 | 10:25 AM
Default Re: VAFC AND TPS QUESTION!????? (shamoo)
no the cable opens the throttle all the way!
Old Dec 2, 2005 | 04:27 AM
zap's Avatar
zap
check your TPS voltage.
smkngsr
11
Oct 11, 2005 05:42 PM
Evilteg
Jul 9, 2003 06:20 AM
Art Vandeleigh
Oct 26, 2002 09:14 PM
98R-1144
Oct 7, 2002 11:28 AM
Black R
Jun 19, 2002 08:06 PM
