Most useful socket set for working on Hondas
Old Dec 7, 2005 | 03:36 AM
tianporn's Avatar
Default Most useful socket set for working on Hondas
Hey Im in the market for a new toolset. Which size drive would more more useful to work on a honda, ie motor, clutch, random things around the car, 1/2 drive or 3/8 drive?
Old Dec 7, 2005 | 04:21 AM
JimBlake's Avatar
Default Re: Most useful socket set for working on Hondas (tianporn)
It's good to have both, but for now I'd start with 1/2. On all the smaller stuff where a 1/2 drive is too big & clumsy, you can use combination wrenches for now.
Old Dec 7, 2005 | 12:25 PM
tianporn's Avatar
Default Re: Most useful socket set for working on Hondas (JimBlake)
Thanks
Old Dec 7, 2005 | 05:35 PM
dfoxengr's Avatar
definitely 3/8.
probably 80 % of bolts on hondas have either 12 or 10 mm heads.
Old Dec 7, 2005 | 06:05 PM
turtle-eg's Avatar
3/8" socket set... you can use most bolts up to 17mm and even 19mm on hondas. The only 1/2" sockets you'll need probably be 32mm, 36mm, and 19mm for the axles, crank bolt, and lug nuts.... but it's good to have both and even a set of 1/4" sockets.
Old Dec 7, 2005 | 06:30 PM
magimerlin's Avatar
Craftsman makes acouple good kits. I have this one with out the wrenches and mine was pre-etch days and it has never failed me yet http://www.sears.com/sr/javasr...e=Yes
Old Dec 7, 2005 | 08:06 PM
ProjectLSVTEG's Avatar
Default Re: (magimerlin)
and if you're going to be doing clutches, pressure plates, flywheels, and the such, you might want to invest in a torque wrench! especially when it comes to valvetrains... damn near ever bolt has a torque spec on it, and its always wise to keep things torqued properly.
Old Dec 8, 2005 | 03:13 AM
tianporn's Avatar
What about for motor swaps, which size will be better? The only use i can think of for the 1/2 drive is to use it to get the axle bolts out. Im sure the 3/8 is able to tackle the other bolts such as the engine mount bolts right?
Old Dec 8, 2005 | 10:42 AM
msmotorsports's Avatar
You don't want either or. You want both sets of wrenches 3/8 and 1/2". If you are truly serious about building a motor/car then you will need both sets. The 3/8 works good for smaller spaces and the 1/2" works well for areas that are open but require more torque. A 3ft. pipe that will slip fit the 1/2" handle will come in very handy as well. May be a little more cash for both sets but a worthwhile investment in the long run.
Old Jul 17, 2024 | 01:18 PM
ElizabethInDFW's Avatar
My 05 has a 36 mm axel nut, the steering knuckle and OEM ball joints (?) are 24mm (and frozen!!) -- which probably means the control arm nuts are as well. Most everything else is 17mm and 10mm with an occasional 12.
ReactioN
12
May 13, 2008 10:19 PM
drumminforev
13
Apr 20, 2006 05:05 PM
ruthless013
14
Jan 28, 2004 01:18 PM
Victor Penner
Mar 3, 2003 07:41 AM
ActiveAero
Oct 26, 2002 11:38 AM
