help cars sputtering and idles bouncing
Old Dec 2, 2005 | 10:08 AM
notsojdmeg's Avatar
Default help cars sputtering and idles bouncing
alright heres tha deal i was drivin last week and out of nowhere my cars idle started bouncing all over tha place? tried to adjust the idle control sensor didnt help. and on top of that when i go to accelerate my car sputters til about 15-20 mph than it runs fine and it does this in every gear? could this be from the distrubutor?
Old Dec 2, 2005 | 03:23 PM
ppfalcon's Avatar
Default Re: help cars sputtering and idles bouncing (notsojdmeg)
what kind of spark plug wires do you have..MSD are horrible seen many cars that were miss firing and idled horrible with MSD's, if your car is n/a go with stock honda wires, if it is F/I go with something like magnecor or nology and upgrade to an external coil.. blaster ss is the best one for high reving engines, but unless you hook up an ignition box to your coil you will not be taking full advantage of it..
hope this helps
Old Dec 2, 2005 | 04:04 PM
.RTErnie's Avatar
sounds like a vacuum leak. check all of your hoses. maybe take a can of air(yes I said can of air) and spray it around your intake side of your head...when the engine stumbles you've found your leak.
jdm_vizionz
Mar 2, 2010 10:49 AM
civic89si666
11
Jan 31, 2008 05:50 PM
notsojdmeg
Dec 2, 2005 11:26 AM
jazz215
Jun 19, 2004 10:19 PM
blackls
Jul 7, 2001 12:37 PM
