HELP WITH A DISTRIBUTOR NOISE 90 CRX
Old Dec 7, 2005 | 09:19 PM
derfyb's Avatar
Default HELP WITH A DISTRIBUTOR NOISE 90 CRX
came home from work heard a noise like a vaccum leak or a bearing, its was kind of low but high pitched, took a mechanics stethascope its coming from the distributor. i never heard anything like it before. anyone with any info for qucik fix i prob look at it before work tomorrow but i cant do anything till next year =p working till the end of the year no days off.
Old Dec 7, 2005 | 09:31 PM
Outsane's Avatar
Default Re: HELP WITH A DISTRIBUTOR NOISE 90 CRX (derfyb)
sounds like the bearings on your distro are going out..
Old Dec 8, 2005 | 04:26 PM
_BEN_'s Avatar
Default Re: HELP WITH A DISTRIBUTOR NOISE 90 CRX (Outsane)
Does it sound like something is loose inside the distributor?
If so the bushings inside of it are probably worn.
I had the same problem once and it even got so bad that it made my intake cam slip.
Heisenberg804
Nov 17, 2017 06:26 PM
erikiksaz1
Jan 8, 2006 06:23 AM
Spoonin
Jun 28, 2003 01:47 AM
guttedEF
Mar 28, 2003 11:58 PM
Xlerate9
Feb 27, 2003 08:31 AM
