cable clutch/pressure plate.....same as hydro?????
Old Nov 28, 2005 | 07:08 PM
SlowSlammedSedan's Avatar
Default cable clutch/pressure plate.....same as hydro?????
i was wondering if a cable clutch and pressure plate setup is the same as a hydro set up..... pleas let me know asap im buyin this motor tomorrow and need some info THANKS!
Old Nov 28, 2005 | 09:07 PM
ironcheftony's Avatar
they pressure plates are the same, the only thing different is the clutch disc, reason behind this is because the spline on the tranny's are diferent so the disc are different but the pressure plates are the same, it depends what tranny u want to use, and u get the clutch disc for that tranny
this is for b-series
Modified by ironcheftony at 11:08 AM 11/29/2005
Modified by ironcheftony at 11:09 AM 11/29/2005
Old Nov 28, 2005 | 11:41 PM
court's Avatar
25 Year Member
d seriries are all interchangeable. for b serries, y1/s1 run a smalller spline 21? ys1/s80 run a larger spline 22? not sure about the spline count, but the literature is accurate
Old Nov 29, 2005 | 07:49 AM
Kendall's Avatar
Default Re: (court)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by court &raquo;</TD></TR><TR><TD CLASS="quote">d seriries are all interchangeable.</TD></TR></TABLE>
Please tell me you're joking.
Old Nov 29, 2005 | 09:03 AM
court's Avatar
25 Year Member
Default Re: (Kendall)
there are exceptions. like 88 transmission
Old Nov 29, 2005 | 09:04 AM
msmotorsports's Avatar
Default Re: (court)
The splines may look very similar to the eye but the hydro is about 1mm larger in diameter.
Old Nov 29, 2005 | 10:07 AM
Default Re: (msmotorsports)
thanks you guys... its a y1 cable tranny that was on it b4 with lsd....and im putttin on a gsr hydro tranny....
so im guessin i would have to change the clutch.....?
Old Nov 29, 2005 | 10:28 AM
court's Avatar
25 Year Member
Default Re: (2KTURBOcIVIC)
changing the inputshaft bearing, t/o bering, plate and disc is always ideal when you have everything out, but technically, only the disc needs to be changed.
Old Dec 2, 2005 | 02:59 PM
JapJunkie's Avatar
Well just figured this out the hard way. Pretty sure the pressure plates on a hydro and cable D series are not the same. Just wanting to get my 89 Si hatch on the road so i threw in an eg D15B7 w/ my ef cable D16A6 Si tranny. Im not sure if I used the EG hydro disc or the EF cable disc, but they seem to fit fine w/ the thow out bearing...once the tranny was on, i was not able to shift out of 1st, which indeed messed up my throw out bearing. My mechanic and I think it was the EG pressure plate that was used.
Just wanted to put in my 2cents, its also my first time doing this hydro or cable tranny clutch jobs, u know not knowing to use watever clutch assembly for the tranny or for the motor. Please correct me if Im wrong.
hammergunner
Aug 31, 2008 01:23 AM
Black R
Sep 12, 2006 10:48 AM
spidermancivic
May 1, 2005 08:31 PM
Sinner
12
Dec 15, 2004 01:23 PM
phrasathane
Feb 10, 2004 05:48 AM
