d15b JDM problem install? PLease help quick
Old Nov 28, 2005 | 05:49 PM
Polish_dude's Avatar
Default d15b JDM problem install? PLease help quick
Old motor was d15b7, blew head gasket and so i bought a d15b (jdm). install went pretty smooth, d15b had an extra sensor so i swapped throttle bodies off my old one, no biggie, problem is , motor cranks but wont start, i put oil on cylinders and cranked it without sparkplugs, then put them on, checked all sensors and firing order is correct, all grounds are good, vehicle has gas, also fuel pump whirrs when u turn key one notch, what could be the problem ?
key points- motor is getting fuel, getting spark... wtf?
so either bad motor or something small?
Old Nov 28, 2005 | 08:52 PM
Tad's Avatar
Tad
did you remove your tps sensor?
if so did you properly set it's voltage when you put it back in?
if not that is definetely why it's not starting.
otherwise check ur dist. timing. and/or cam/crank timing(though I dunno why cam/crank timing would be off..)
Old Nov 28, 2005 | 09:09 PM
ironcheftony's Avatar
keep cranking it untill it starts, cehck timing as well,
Old Nov 29, 2005 | 10:42 PM
boost'd_crx's Avatar
Default Re: d15b JDM problem install? PLease help quick (Polish_dude)
you can check if the motor is good or bad by a leakdown and compression test. you should check timing and if your injectors are firing.
brezzent
Oct 30, 2011 06:43 AM
hatche1
12
Apr 21, 2011 11:03 PM
quikcivic94
Jun 14, 2006 11:09 AM
DC4cedInducted
Apr 12, 2006 07:21 AM
