Help should pilot bearing spin
Old Sep 10, 2006 | 09:21 PM
AFFIRMED's Avatar
Default Help should pilot bearing spin
Iv searched and searched for this my clutch makes a noise when I release it.When its in it does't make a noise.I have replaced the throwout bearing and slave cylinder and tranny still same noise. I took the clutch off and the pilot beaing spins is this normal or is this my problem help me please thank you.
Old Sep 11, 2006 | 12:19 PM
unknown0001's Avatar
Default Re: Help should pilot bearing spin (AFFIRMED)
The pilot bearing is supposed to spin
Old Sep 11, 2006 | 01:13 PM
Enzo Speed's Avatar
Default Re: Help should pilot bearing spin (Mr.RHTuner)
Maybe the new tranny has the same busted input-shaft bearing. I doubt if the pilot bearing is making the noise.
Old Sep 11, 2006 | 01:55 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Help should pilot bearing spin (Enzo Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo Speed &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the new tranny has the same busted input-shaft bearing. I doubt if the pilot bearing is making the noise.</TD></TR></TABLE>
I do concur.
Old Sep 11, 2006 | 08:06 PM
AFFIRMED's Avatar
thanks for the help im sure I found the problem.Im running a twin disc clutch so I took it off to change the pilot bearing and noticed
one of the pads was completly striped from the inside that goes on the tranny they are sending me another should be here this week.
Baron55
Dec 19, 2006 06:25 PM
puertoroc7976
Oct 9, 2006 07:11 AM
candy eg
Jan 12, 2006 08:48 PM
AJxr
21
Jan 11, 2006 03:21 PM
XRacerX
Mar 10, 2004 09:14 PM
