96 d16y7 overheating
Old Sep 10, 2006 | 09:22 PM
96EkCivicBronze's Avatar
Default 96 d16y7 overheating
my motor is over heating, not sure why, i have coolant in the radiator, but it still over heats when i'm sitting still, or when i have my heat on, i think it could be the headgasket, not sure though, but i also have a problem with where the dipstick goes the whole thing came out, not sure what to do to fix that, if it's even able to be fixed.. anyone have any ideas let me know..
Old Sep 10, 2006 | 11:04 PM
goodnight bumps..
Old Sep 11, 2006 | 03:03 PM
haji's Avatar
Default Re: 96 d16y7 overheating (96EkCivicBronze)
over heating... check ur radiator fans if their coming on... pressure test the whole coolant system and make sure u dont have any leaks... check or replace the thermostat its only like 5 bucks....incorrect ignition timing wil also cause overheating.. check ur coolant for any oil mixed in with it... or ur oil for any coolant mixed in it.. or if ur oil looks like chocolate milk..if so. headgasket. make sure u dont have any codes (check engine light) its alot of things that can cause it to overheat. make sure ur fans are coming on first.
Old Sep 12, 2006 | 07:31 AM
Default Re: 96 d16y7 overheating (haji)
well thank you.. i figured as much, i'm getting a full radiator from a buddy out of a teg.. so.. but yea i need to check my fans, i don't think they are coming on, but it also over heats when i turn on my heat.. well i'll check these things, thank you..
Old Sep 12, 2006 | 10:22 AM
Crazydave's Avatar
Check out this thread for troubleshooting overheating:
https://honda-tech.com/zerothread?id=1671350
509b16
17
Dec 27, 2023 08:01 PM
Teamdiesel
40
Dec 3, 2019 04:10 PM
ROSSIL25
Mar 25, 2009 05:30 PM
lisajasmin
11
May 25, 2008 10:42 PM
smokerz212
Jan 8, 2007 05:13 PM
