code 22, Vtec pressure sensor, Does it work??
Old Sep 12, 2006 | 07:32 PM
Metal Head's Avatar
Default code 22, Vtec pressure sensor, Does it work?? ** updated**
I have a problem with my car, Driving on the highway, the CEL light came on, I turned the car off then on and the light went off and stayed off. I was concerned about it and checked to see if I got any codes. Got code # 22 two long blinks and 2 short blinks. Now I was told the code os for the Vtec sensor, So I swapped out sensors, reset the ECU, and I still get code 22, WTF???
in conclusion, I took the black wire on the green plug on the pressure sensor, spliced in a wire and grounded it directly to the battery negative terminal, checked what wire connections I could and all seemed to be fine, reset ECU 2 times and I still throw 22, Although, like I said, I DON'T get CEL, but I throw the code. How do I tell if VTEC is working?
Someone help a newb out please!
**updated**
ok, so, I wired the pressure switch directly to the ecu, I cut the wie off the plug, and spliced in my own wire, fed it into the firewall, and ran it to the ECU, now, recet the ecu, I now get code #21 which is for VTEC sylenoid, WTF??????
Modified by boostless95ex at 2:40 PM 9/27/2006
Old Sep 12, 2006 | 11:18 PM
mtber's Avatar
Default Re: code 22, Vtec pressure sensor, Does it work?? (boostless95ex)
What ecu are you running ?
A multi-meter with continuity checking would be your best bet.
If all else fails, bypass the vtps: http://phearable.net/tech
Old Sep 13, 2006 | 07:37 PM
Metal Head's Avatar
Default Re: code 22, Vtec pressure sensor, Does it work?? (mtber)
im sorry, its an P28 stock ex ECU. so what do I need to do?
Old Sep 13, 2006 | 07:39 PM
Metal Head's Avatar
now why would I want to bypass the pressure switch? Will Vtec still work?
Old Sep 14, 2006 | 12:51 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
If you throw a Code 22, check your damn oil. Thats the pressure switch and if it doesn't have enough oil pressure, it will throw the code and VTEC will no longer work. You have obviously already elimitated the sensor as the problem.
Old Sep 14, 2006 | 06:36 AM
Metal Head's Avatar
Default Re: code 22, Vtec pressure sensor, Does it work?? (JDM_Ej)
I DID check my oil and it ia FINE!!
Old Sep 17, 2006 | 09:08 PM
Metal Head's Avatar
top
Old Sep 18, 2006 | 06:01 AM
so lazy's Avatar
i would try and run that blue wire str8 to the ECU by yourself to see if that problem is in your harness... its not that hard worth a try.
Old Sep 27, 2006 | 01:41 PM
Metal Head's Avatar
Default Re: code 22, Vtec pressure sensor, Does it work?? (dc2-guy)
**update**
So I took the Vtec pressure switch and wired it DIRECTLY to the ECU, ret the ecu, and now I get Code #21 Wich is Vtec sylenoid, WTF now???????
Old Sep 27, 2006 | 07:07 PM
Metal Head's Avatar
**update a second time**
So tonight I wire the VTEC sylenoid DIRECTLY to the ECU, rest the ecu for 30 min, and I STILL get code #21 WTF????? I have already put on a new vtec sensor......
Old Sep 28, 2006 | 10:06 AM
Gak Attack's Avatar
Give up, Problem solved.
Old Sep 28, 2006 | 11:39 PM
Metal Head's Avatar
Default Re: code 22, Vtec pressure sensor, Does it work?? ** updated** (boostless95ex)
top
Jdmkids Manny
17
May 12, 2016 02:18 PM
racereaper7
Aug 14, 2007 08:56 AM
Metal Head
Sep 15, 2006 02:35 PM
Ls1 FD3s
May 18, 2004 12:19 PM
RoaringTurtle
18
Aug 5, 2002 01:17 PM
