WHAT REALLY HAPPENS..
Old Sep 3, 2006 | 08:37 PM
gmboogy's Avatar
Default WHAT REALLY HAPPENS..
WHAT HAPPENS WHEN YOU OVER REV YOUR CAR?
Old Sep 3, 2006 | 08:42 PM
mmuller's Avatar
Mad Scientist
Default Re: WHAT REALLY HAPPENS.. (gmboogy)
you can cause valve float wich equals bent valves or worse
Old Sep 3, 2006 | 09:34 PM
gmboogy's Avatar
Default Re: WHAT REALLY HAPPENS.. (mmuller)
is it ok to rev 2 notches over 8 on a gsr?
Old Sep 4, 2006 | 11:01 AM
atg1290's Avatar
I wouldnt over rev period..why risk it all?
Old Sep 4, 2006 | 12:22 PM
gmboogy's Avatar
Default Re: (atg1290)
i didn't do it on purpose.
Modified by gmboogy at 1:35 PM 9/4/2006
Old Sep 4, 2006 | 01:11 PM
TwoRedEGgs's Avatar
Default Re: (gmboogy)
It really depends on how it happens and how high it goees before you catch it. You can miss the gear and bounce it off the limiter and nothing happens most of the time. But if you mechanically over rev the motor, like going from redline 3rd to 4th but you miss and get 2nd there is a very good chance that you can do allot of damage, but you may get lucky and get teh clutch back in quick enough not to let it rev that high. Worst case can be seen below in these pics.
Old Sep 4, 2006 | 01:24 PM
Lsos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gmboogy &raquo;</TD></TR><TR><TD CLASS="quote">WHAT HAPPENS WHEN YOU OVER REV YOUR CAR?</TD></TR></TABLE>
A couple things. Stresses in an engine rise exponentially with rpms, so if you overrev enough and the stresses get high enough, parts break and you have catastrophic engine failure.
A less-bad scenario is that the springs that hold valves against the cams are too weak to do it at the elevated rpms, and the pistons smack into the valves. Parts still break/ fail, but at least you might not have total engine destruction.
The second scenario might still leave you with a relatively well functioning engine, but one that still needs to be repaired. This can get costly if you can't do some of the work yourself. I suggest you simply remove the head and give it to a machine shop for rebuild. Make sure they don't put the rocker shafts in backwards. It's a pain in the *** if you realize they did this after you put the head back onto the engine.
Don't ask me how I know.
Old Sep 4, 2006 | 06:48 PM
gmboogy's Avatar
thanks for the replies. i probably wasn't too clear on what happend though. i redlined 3rd gear and missed 4th gear and reved a lil over 8. maybe to 2 to 3 notches over. hopefully i that didnt do a lot of damage. it was just bugging me the past couple of days because i'm pretty new to this stuff.
Old Sep 4, 2006 | 07:59 PM
mmuller's Avatar
Mad Scientist
i would not worry about it. mechanical overrev is what kills
Razr2
15
Jan 1, 2008 10:24 PM
fandirabbani08
Honda Civic (2006 - 2015)
Feb 16, 2007 12:47 PM
HamiltonRex
Jul 18, 2006 07:42 PM
JDM00SI
Jan 30, 2005 06:43 PM
Loveless
Jun 23, 2003 09:40 PM
