LS transmission Leaking...
Old Sep 4, 2006 | 05:55 PM
Topdawgg's Avatar
Default LS transmission Leaking...
So I did a transmission swap in my car a couple weeks ago, and the car was layed up... but tonight I noticed that the tranny is leaking... Ive done tranny swaps before and never had this problem...
What is common for bseries trannys? Anything i should know that could help me...
It appears to be leaking from around the bottom, but i couldnt notice where until i can get the car up in the air and take a look
just wondering if anyone has had similar problems
Old Sep 4, 2006 | 08:29 PM
mahatma's Avatar
Default Re: LS transmission Leaking... (Topdawgg)
axle seals would be my 1st suspect
Old Sep 5, 2006 | 02:06 PM
ffHeart's Avatar
Check your axle seals and shift shaft seal.
Old Sep 5, 2006 | 04:49 PM
Topdawgg's Avatar
Default Re: LS transmission Leaking... (ffHeart)
shift shaft seal?
Old Sep 5, 2006 | 05:06 PM
SkRiBLaH's Avatar
no no no and no.
check:
drain bolt
fill bolt
has the trans ever been split? if so check the sealing job
then check axle seals.
Old Sep 5, 2006 | 09:28 PM
mahatma's Avatar
Default Re: LS transmission Leaking... (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">no no no and no.
check:
drain bolt
fill bolt
then check axle seals.</TD></TR></TABLE>
OMG you're right!! don't check the axle seals 1st, whatever you do!!!
OP, apparently the odds are that you're a moron who couldn't handle tightening the fill & drain bolts
Old Sep 6, 2006 | 06:57 PM
Wes V's Avatar
Default Re: LS transmission Leaking... (mahatma)
Check all the above and also look <U>REAL</U> close at the case to see if the prior owner may have bottomed out the car and hit the trans.
I bought a used transmission and found the case was cracked when I went to rebuild it (prior to installing it). The outside didn't look bad, but the crack was clearly visable from the inside. (the seller was a good guy and got me a replacement case)
Wes
b20bFourDoorCivicLX
Transmission & Drivetrain
Mar 5, 2012 11:52 PM
jasony0630
Mar 18, 2008 11:04 AM
whatsthatnoise
Oct 10, 2006 03:09 PM
vtec25
Mar 16, 2006 06:54 PM
vtekthis
Mar 24, 2004 06:11 PM
