CRX B16 trouble
Old Sep 3, 2006 | 12:52 PM
JDM91Bseries's Avatar
Default CRX B16 trouble
I have a 91 CRX HF with a complete JDM B16A swap from hmotors. Everything was put in by a shop and its throwing a code 9(cylinder position sensor). How do i get rid of this? Also when i brought the car home from the shop, i was on the highway doing 60mph and it started cutting out like the injectors and possibly ignition were not firing. Not sure but thats what it acted like. I could push in the clutch and let it idle for a little while then i could resume driving until i had it over 3000 rpm for a little bit...then it would do the same thing. Someone please let me know how to solve these problems.Much appreciated.
Scott
Old Sep 3, 2006 | 01:27 PM
onepoint6i's Avatar
Default Re: CRX B16 trouble (JDM91Bseries)
either you have a loose connection, or you have a bad distributor..try a known good distributor...or check continuity @ the cyl sensor per a service manual...
Old Sep 3, 2006 | 05:04 PM
Is it ok to drive it with this code on and it acting like it does? Also which connections and where should i check for loose or corrosion on which connections? Thanks
Scott
Old Sep 3, 2006 | 09:56 PM
anyone know?
Old Sep 4, 2006 | 05:12 AM
Cory man's Avatar
Default Re: (JDM91Bseries)
I wouldnt drive it with that code present. The car can turn off or stall when you need to accelerate and cause an accident. Fix it and be done with it.
Cory
Old Sep 4, 2006 | 10:39 AM
Thanks for the info so far. If anyone has any other thoughts or ideas, please post them. Thanks
Scott
Old Sep 4, 2006 | 10:57 AM
onepoint6i's Avatar
the cyl postion sensor is inside the distributor, check the plugs inside of it, also check the ecu connections/pins...more than likely your distributor is bad being that those sensors on obd 0 dist's always go bad..
Old Sep 4, 2006 | 10:59 AM
killabeezturbo's Avatar
no your car will not stall and couse an acedint u just cant drive the car with it red lining at the rpms that is doin the prob but the problem could be that one of your plugs can lose and can be causing the problem maybe a lose ground wire i had the same problem and also was your car previously a dpfi car dual point carb the wiring can be the problem. if it was i suggest u go to the person or shop that wired your car to dubble check the work and corect ur check eng code if they cut the ecu plugs to wire things there make shoure that the wire dont have any play
Old Sep 4, 2006 | 01:12 PM
Basically i need to know if it will hurt anything to drive it around. Because the shop is about 40 miles from me and if it wont hurt anything i was gonna drive it to work. Letme know guys. Thanks
Scott
Old Sep 4, 2006 | 07:25 PM
bump
Old Sep 4, 2006 | 08:29 PM
onepoint6i's Avatar
nah it wont hurt anything...its just gonna run really rough if anything...it might stall out on you pretty bad depending on how much the ecu is not reading the signal..
Old Sep 5, 2006 | 07:08 AM
Ok, thanks for the replys. Going to take my car back to the shop and have them look over everything again. Hopefully get it fixed.Thanks
Scott
eghonda1320
16
Oct 23, 2012 03:23 PM
vtec_ef8
Oct 2, 2010 07:17 PM
Lethalb18c1
Nov 22, 2006 08:15 PM
done
Oct 8, 2002 03:37 PM
