!!!!!!need help!!!!!!
Old Sep 4, 2006 | 07:04 PM
fastcrx89's Avatar
Default !!!!!!need help!!!!!!
ok i just put my 91 ls motor into my 89 crx dx now it is having trouble starting, and when it does it stutters and when you go to give it gas it shuts off. what could it be??? my ecu is throwing a code 14 i think it is a (IAC) but not sure i had another one and put it on but same outcome but it could also be bad. the car is obd0 so maybe you guys could help out any advice is good .
thanks for your time
ricky
Modified by fastcrx89 at 8:37 PM 9/4/2006
Old Sep 4, 2006 | 08:34 PM
mahatma's Avatar
Default Re: !!!!!!need help!!!!!! (fastcrx89)
the iacv and another sensor (can't remember which) have the same plugs and can reach one another.
maybe you just mixed them up.
otherwise based on the symptoms you describe, i'd guess that the engine is out of time. bad idle....bogs / shuts off when you give it gas = timing is off
Old Sep 4, 2006 | 08:43 PM
fastcrx89's Avatar
thank a cupple of people said that thanks for your help
Old Sep 5, 2006 | 07:21 AM
fastcrx89's Avatar
thanks for the help so far i think i might have the tps and map sensor swaped but not sure
ludesrv
Dec 30, 2006 03:31 PM
c1civic
Apr 4, 2004 06:15 PM
The Brown Kid
Oct 23, 2003 03:20 PM
89hb
Jan 11, 2003 01:22 PM
CRexDX
Mar 26, 2002 10:45 AM
