Tach signal wire
Old Sep 6, 2006 | 07:00 AM
Mikey3000's Avatar
Default Tach signal wire
should the tach signal wire's voltage change as the engine speed varies? i'm having a problem with my tach not working like it should. i checked the voltage at the tach signal wire (at the driver's side harness, light blue wire) and it stays constant around 12-13 volts even when the engine speed changes.
Old Sep 6, 2006 | 08:21 AM
Relic1's Avatar
tach signal is a waveform not a voltage.
all though checking it with a volt meter should appear like the voltage changes with RPM.
I don't think the tach line should ever have 12V on it...
Old Sep 6, 2006 | 08:32 AM
Mikey3000's Avatar
Default Re: (Relic1)
so what can i test to see if the tach is getting a good signal?
Old Sep 6, 2006 | 02:32 PM
Relic1's Avatar
o-scope or tach.
gnarlycs
Jun 13, 2012 02:30 PM
90crxdriver
10
Nov 4, 2006 12:14 PM
team2n1hatch
Jun 18, 2003 09:37 AM
Eg6_JDM
Mar 18, 2002 10:33 AM
