B18C5 problems!
Old Sep 12, 2006 | 10:42 PM
iamhollywood[BRS]'s Avatar
Default B18C5 problems!
So I'm pulling out of a parking lot and go to shift into second, get it in gear and all the sudden the motor feels like it starts to suffocate. I give it more gas and its JOLTS back to life. it aslo does this if I let off the gas and then give it gas again.
I can't check the code because the cluster I have didn't have a CEL light. any info as to what could be the problem would be GREATLY APPRECIATED!!!!!!!! thanks guys!
Old Sep 13, 2006 | 12:56 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: B18C5 problems! (iamhollywood)
Um, what cluster wouldn't have a CEL?
Seems like a MAP sensor problem? Maybe?
Old Sep 13, 2006 | 08:39 AM
:Andrew's Avatar
do you mean there is no bulb for the cel light in your cluster?
Old Sep 13, 2006 | 09:13 AM
Default Re: B18C5 problems! (:Andrew)
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :Andrew &raquo;</TD></TR><TR><TD CLASS="quote">do you mean there is no bulb for the cel light in your cluster?</TD></TR></TABLE>
yeah, the guy I bought it from didn't tell me he removed the bulb
Old Sep 13, 2006 | 10:18 AM
up!
Old Sep 13, 2006 | 01:13 PM
egsleepercivic's Avatar
the only reason someone would remove the CeL bulb would be to hide a CEL when selling a car, get a bulb and have fun with your cels
gl
Old Sep 13, 2006 | 04:02 PM
Default Re: (egsleepercivic)
this isn't the cluster that came with the car. nor is it the motor that came with it....
Old Sep 13, 2006 | 04:10 PM
well thats good, I would still install a new bulb to check the codes
My best guess would be coil
gl
Old Sep 16, 2006 | 07:33 PM
bump. anyone else have any ideas till I can pick up a CEL?
Old Sep 16, 2006 | 10:17 PM
so lazy's Avatar
Default Re: (iamhollywood)
man it could be lots of things... dissy.... tps sensor(on the TB)... gas probelms... get that light fixed its not that much trouble... lol its a .50cent bulb...
Old Sep 16, 2006 | 10:45 PM
Default Re: (dc2-guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2-guy &raquo;</TD></TR><TR><TD CLASS="quote">man it could be lots of things... dissy.... tps sensor(on the TB)... gas probelms... get that light fixed its not that much trouble... lol its a .50cent bulb...</TD></TR></TABLE>
haha, word. trust me I know. im working 2 jobs and am a college student. I'm strapped for time to even breath. but I plan on picking up the bulb this week and getting it figured out... I'd just like to see if I can get any ideas from you guys for a head start. thanks everyone who has chimed in!
Old Sep 17, 2006 | 02:10 PM
so lazy's Avatar
just get that light fixed and post the CEL, someone will help you out.. or pm me i wouldn't mind helppin a fellow H-T member
Old Sep 17, 2006 | 09:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2-guy &raquo;</TD></TR><TR><TD CLASS="quote">just get that light fixed and post the CEL, someone will help you out.. or pm me i wouldn't mind helppin a fellow H-T member</TD></TR></TABLE>
thanks man! I got the bulb in there this morning and jumped the ecu. got a code 7 for the tps. now I need to figure out if it just needs to be adjusted or if its going out. any suggestions/personal experience/guidance is much appreciated! and thanks dc2-guy! ill definitely pm you with any diffuculties!
Old Sep 18, 2006 | 05:56 AM
so lazy's Avatar
the tps your not suppose to change them out so honda tells me all the time at work but F it just take it off a Civic or something use a hacksaw and cut alittle groves into the oneway screw that holds the tps in... but the right way is to get a new TB.. but i'm hardheaded and try to get out the cheap way.. good luck..
brooklynboy
Apr 28, 2015 10:52 AM
Dedotut
May 22, 2009 05:12 PM
Crasian
10
Jul 24, 2007 07:12 AM
crew08 (girlygirlracer)
23
Mar 24, 2005 02:54 AM
96HatchB18
Nov 11, 2002 06:19 PM
