Symptoms of a bad halfshaft?????
Old Sep 5, 2006 | 06:54 AM
DeDonDeRosa's Avatar
Default Symptoms of a bad halfshaft?????
need to know what the symptoms of a bad halfshaft would be
is there a way to tell my moving it ? looking at it ? or what.
so i need to know what would the symptoms be please thank you
Old Sep 5, 2006 | 01:37 PM
Perfectionist's Avatar
Default Re: Symptoms of a bad halfshaft????? (DeDonDeRosa)
Basically, the half shaft has 2 CV joints. The outer may click if worn when the steering is turned full lock to one side while the car moves. The inners may cause a vibration during acceleration if they are worn. The boots, if torn, are a sure sign of dirt contamination and possible furure failure. There is some play in the joints, so unless you are very familiar with them, it would be difficult to diagnose their condition by moving them by hand.
Old Sep 6, 2006 | 12:39 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Symptoms of a bad halfshaft????? (Perfectionist)
Are you talking about axles? Or the intermediate shaft?
Old Sep 6, 2006 | 03:47 AM
Default Re: Symptoms of a bad halfshaft????? (JDM_Ej)
INTERMEDIATE SHAFT the part that goes in the trans on the drivers side
Old Sep 6, 2006 | 07:37 PM
GRANT!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">INTERMEDIATE SHAFT the part that goes in the trans on the drivers side</TD></TR></TABLE>
ever get an answer?
Old Sep 6, 2006 | 08:10 PM
Default Re: Symptoms of a bad halfshaft????? (K . I . N . G !)
nope
Old Sep 6, 2006 | 11:25 PM
HamiltonRex's Avatar
Well.. As far as i know, there isnt much that can wear out on it, Except the bearing on the end, which i doubt you could really inspect it too well installed on the veichle.
slo_ej8
Mar 19, 2008 08:27 PM
hu
Mar 24, 2007 03:16 PM
gurgle
Mar 21, 2006 05:57 AM
opiumdaze
Feb 13, 2006 09:50 PM
stivic
18
Sep 6, 2004 12:53 PM
