Intake manifold swap- problems- looking for suggestions
Old Sep 6, 2006 | 07:47 PM
crAppAchic0's Avatar
Default Intake manifold swap- problems- looking for suggestions
Okay - I have a '91 CRX Si, with the original d16a6 motor- finally got ahold of an intake manifold from a d16z6, so...
plopped on a b16a (1st gen) TB and reused my original injectors- split the vacuum line going to the oem fuel pressure regulator to hook up the dashpot on the throttle body (which doesn't quite seem to function right) - everything else is set as it was with my original intake manifold, except for the complete lack of a fast idle control valve (just taped off the plug)-
So I got everything in and started it up- only to get a code 14, EACV (or IACV in this case)... the idle seems fine, but as soon as I give about 1/8 to maybe a 1/4 throttle, the engine surges- until I get to about maybe a 1/3rd pedal, at which the engine just revs right up as normal. I checked for voltage across both wires going to the EACV/IACV and no voltage between the two, voltage from BLK/YEL to ground, but none from Blu/(whatever) to ground. When battery voltage is applied, the IACV does click open and closed.
Any ideas? any at all would be greatly appreciated.
Oh and before swapping intake manifolds - the engine threw no codes and ran fine.
Modified by crAppAchic0 at 9:34 PM 9/6/2006
Old Sep 7, 2006 | 09:30 AM
Default Re: Intake manifold swap- problems- looking for suggestions (crAppAchic0)
Anyone? Some random thoughts?
Old Sep 7, 2006 | 05:40 PM
lightcrx's Avatar
what you mean you just taped the plug off(fast idle valve)
-joseph
Old Sep 8, 2006 | 06:35 PM
Default Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">what you mean you just taped the plug off(fast idle valve)
-joseph </TD></TR></TABLE>
The z6 intake has no fast idle valve- and there is no sensor in it, the ecu only controls it based on temperature. So unplugging it does not throw a CEL.
I spent a bunch more time today trying to figure it out-
Unplugged the dashpot on the throttle body thinking it could have been a vacuum issue to the fuel pressure regulator- nothing. unplugged the brake booster and plugged off that outlet (just to make sure) - nothing again.
I'm still getting the code 14, for the EACV- would this make the engine surge, regardless of engine speed- only when the throttle is applied? The idle is fine and smoothe. I tried swapping the fuel pressure regulator off my old fuel rail - no difference.
I unplugged the vacuum line from the fpr, and plugged it off- no difference.
The only consistent thing has been that stupid error code- would a code 14 (EACV malfunction) cause engine surging?
Has anyone else swapped a d16z6 intake manifold & b16a(or b18a1- I think) throttle body onto a d16a6 head & block? Any issues?
Old Jul 29, 2011 | 02:35 PM
Just to bump a ridiculously old thread- I did fix the problem- the harness going to the EACV was hacked apart by the previous owner- the two wires were swapped. Swapped them back and everything was happy.
I Like Hondas
Jun 22, 2008 02:59 PM
pbink
Oct 26, 2005 11:52 AM
jumpman83
Oct 16, 2005 01:45 PM
pro547
Mar 19, 2005 02:26 PM
john944
12
Apr 15, 2003 11:56 PM
