Valve Seals, Valve lapping Compound?? Help guys
Old Nov 16, 2006 | 07:57 PM
bb4socal's Avatar
Default Valve Seals, Valve lapping Compound?? Help guys
Need some help with Valve Seals. Take a look and see if you could help me out! Thansk guys!
https://honda-tech.com/zerothread?id=1812838
Old Nov 17, 2006 | 06:51 AM
CompressionFed's Avatar
Default Re: Valve Seals, Valve lapping Compound?? Help guys (bb4socal)
It seems like your question was answered, what don't you understand? BTW, someone said it before but I'll say it again...don NOT use lapping compound at the seal. The compound is to help seat the valves into the valve seats. They come in coarse and fine. Use coarse first, then fine obviously. Take a cordless drill (or corded will work too) and a piece of rubber tubing. One end of the tubing goes into the dril, the other around the valve stem (helps to use zip tie).
Good luck.
Old Nov 17, 2006 | 07:08 AM
mmuller's Avatar
Mad Scientist
Default Re: Valve Seals, Valve lapping Compound?? Help guys (CompressionFed)
i wouldnt even use the evil lapping compound on the valves..
Old Nov 17, 2006 | 08:37 AM
Default Re: Valve Seals, Valve lapping Compound?? Help guys (mmuller)
It's not the best choice, but if he's on a tight dollar, or a DIYer, I have used it before with no problems.
KoRE
Apr 13, 2010 09:40 PM
averyvm
May 21, 2007 08:06 PM
bb4socal
Nov 18, 2006 07:02 AM
SpoolnByYou
Mar 16, 2006 12:49 PM
devand1dawg
Mar 7, 2005 11:53 AM
