B20vtec idling problem, HELP!!!!
Old Nov 12, 2006 | 02:38 PM
SpoonEk253's Avatar
Default B20vtec idling problem, HELP!!!!
My b20vtec wont seem to stay idling and has sudden surges from 1500-2500rpms but im only throwing code 10? anyone know my problem and know how to fix it?
Old Nov 12, 2006 | 07:10 PM
SpoonEk253's Avatar
Default Re: B20vtec idling problem, HELP!!!! (SpoonEk253)
ttt
Old Nov 12, 2006 | 07:35 PM
93lsd's Avatar
checkfor a air leak or your idle air control may be goiong bad
Old Nov 14, 2006 | 03:40 PM
SpoonEk253's Avatar
Default Re: (93lsd)
how u check for a air leak? i dont think its my idle control valve because wouldnt i get a cell code for that?
Old Nov 18, 2006 | 03:55 PM
SpoonEk253's Avatar
Default Re: (SpoonEk253)
some help here...
Old Nov 19, 2006 | 08:01 PM
Stop the Beast's Avatar
try carb cleaner, you'll notice the engine bog when the leak intakes the carb cleaner. Check around the head flange, tb, and brake booster lines. if you have a fast idle thermo on the tb, make sure the plunger is seated in it correctly.
Old Nov 20, 2006 | 07:27 PM
SpoonEk253's Avatar
Default Re: (Stop the Beast)
well im using a skunk2 manifold so im not gonna have the fast idel thermo sensor and its obd2
Old Nov 20, 2006 | 08:37 PM
The fast idle thermo is on the TB not the intake manifold. That's the easy fix, the other ones may or may not be trickier to find.
Old Nov 21, 2006 | 05:31 AM
SpoonEk253's Avatar
got a picture of that...because i dont believe a obd2 gsr tb has that on it
Old Nov 21, 2006 | 02:18 PM
Yeah, those are only found on Automatic cars that I know of, not sure where you may have got the tb. Anyhow, rule that one out
Old Nov 21, 2006 | 02:23 PM
qfast817's Avatar
i have it on my 95 gsr, its rie under the tb also could be your iac
Old Nov 22, 2006 | 07:36 AM
Oh, totally forgot. My b20/vtec would idle like crap on my PR4 ECU (that's obd-1 LS correct?).
I made damn sure there were no leaks and the idle screw would only add to the chaos. It just woudn't idle right. Until, I got a custom map done with Neptune (Thanks LoCash Joe!). Other then that and some spark plugs, 7s, now she purrs at 900rpm solid.
Old Nov 22, 2006 | 02:32 PM
SpoonEk253's Avatar
Default Re: B20vtec idling problem, HELP!!!! (Stop the Beast)
yea im using a obd1 jdm p30 and i made sure theres no leaks...i replaced all vaccum lines and even the throttle body it self and gasket....and it still wont idle right. when i use to have my obd2 p72 everything worked great but now everything works like crap! haha
Old Nov 23, 2006 | 07:35 PM
SpoonEk253's Avatar
2 dee top
ridin98civic
Dec 28, 2007 01:45 PM
SpoonEk253
Nov 25, 2006 11:50 AM
ITRacer121
11
Mar 25, 2005 01:49 PM
[ iLL ] iNt3GrA
Jun 16, 2004 05:44 PM
CrX1988Zc
Sep 16, 2002 04:26 PM
