Removing Stuck Wrist Pins
Old Nov 5, 2006 | 08:57 PM
SaM DA Man's Avatar
Default Removing Stuck Wrist Pins
Well i have some pistons that are stuck on the rods...i can't see to remove the wrist pins. Tried hammering it out....any suggestions?
Old Nov 5, 2006 | 09:02 PM
HEAD's Avatar
Default Re: Removing Stuck Wrist Pins (SaM DA Man)
well if there stock rods you have to heat the small end to get them out, there press fit. Most machine shops will have the tools and the heater to do it right. The way your going your going to crack the piston.
Old Nov 5, 2006 | 09:04 PM
SaM DA Man's Avatar
Default Re: Removing Stuck Wrist Pins (HEAD)
They are forged pistons on stock rods and i cant get them off argh! Would some kind of press help?
Old Nov 5, 2006 | 09:10 PM
Mike K's Avatar
they are still press fit. you need to take them to a machine shop. you don't want to risk overheating them by using a torch yourself.
Old Nov 5, 2006 | 09:16 PM
SaM DA Man's Avatar
Default Re: Removing Stuck Wrist Pins (Mike K)
Do you know how much this costs?
Old Nov 5, 2006 | 09:20 PM
HEAD's Avatar
way less then a new set a pistons! $100 bucks at the most..if it's a full floating pin just take the locks out but on stock rods you'll need to take them somewhere
NwAmH
May 17, 2007 01:39 PM
anrkii
Oct 5, 2006 07:56 AM
FoShizzle
Nov 30, 2004 08:53 AM
tegasaurus
Jul 15, 2004 01:09 PM
RedlinedVTEC
Jul 29, 2003 04:57 PM
