How do you measure valve guide bore?
Old Aug 9, 2007 | 01:03 AM
Legion's Avatar
* B A N N E D *
Default How do you measure valve guide bore?
My exhaust valves feel a bit too wobbly, so I'm trying to determine of the valve-to-guide clearance is out of spec. The valves check out fine, but I'm not sure how to measure the guide bores. Some sort of tiny dial bore gauge or something?
Old Aug 9, 2007 | 04:41 AM
mmuller's Avatar
Mad Scientist
Default Re: How do you measure valve guide bore? (Legion)
well without super expensive tools yo can check valve side to side movement with a base and dial gage. see if its within spec
Old Aug 9, 2007 | 06:10 AM
pomansouth01's Avatar
Ginger Kid
take it to a machine shop, they will have things that look like dowels that are tapered slightly and are certain diameters....they will check it out for you...
Old Aug 9, 2007 | 07:56 AM
Legion's Avatar
* B A N N E D *
Default Re: (pomansouth01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 &raquo;</TD></TR><TR><TD CLASS="quote">take it to a machine shop, they will have things that look like dowels that are tapered slightly and are certain diameters....they will check it out for you...</TD></TR></TABLE>
Hmmm... What are these things called? I wonder if I can buy just the one size I need.
Old Aug 9, 2007 | 09:30 AM
RACEPAK's Avatar
Default Re: (Legion)
bump cause i want to know too.
Old Aug 9, 2007 | 10:15 AM
Jon F's Avatar
Hole (bore) gauges on ebay:
http://cgi.ebay.com/4-PC-PRECI...wItem
I think pomansouth01 is referring to a tapered pilot, which is a good way to measure the minimum size of the bore. You'll want to measure the maximum size, though, to indicate wear. You'll need a good micrometer to go with the bore gauge.
Old Aug 9, 2007 | 10:20 AM
Legion's Avatar
* B A N N E D *
Default Re: (Jon F)
Funny, I actually looked at that auction already. I just discredited it as being legit when I saw the price.
Old Aug 9, 2007 | 03:30 PM
stumpyf4's Avatar
Use a pin gauge set... like feeler gauges but for holes.
http://www.micron-inc.com/gage.htm
Old Aug 10, 2007 | 05:38 AM
Mikey3000's Avatar
Default Re: (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">Use a pin gauge set... like feeler gauges but for holes.
thats what you want.
Old Aug 10, 2007 | 12:50 PM
slowcivic2k's Avatar
Default Re: (Mikey3000)
You can also use a split ball gauge (small hole/small bore gauge), which will be much more accurate, and is expandable so that you get a good fit, like a mic or feeler gauge.
A small set (usually 4 or 5 different ones) can run you about 80 bucks, but I would not use this if its a one time only deal, since you really should use a micrometer with this as well.
ChillinInTheDA
Jan 5, 2011 06:28 AM
vtec.dc2
Apr 26, 2005 07:57 AM
redcrx187
19
Oct 14, 2004 07:29 PM
NomacGSR
Aug 1, 2003 05:19 AM
