need help!!!! h22 swap is slooooow
Old Aug 13, 2007 | 01:50 AM
h2bv8killa's Avatar
Default need help!!!! h2b swap
well i finished my h2b swap yesterday and took it out for a ride and there's litterally no difference from the single cam...theres absolutely no power/torque curve... it is throwing a tps code. could a bad tps sensor cause a huge power loss?
Modified by h2bv8killa at 9:51 AM 8/13/2007
Modified by h2bv8killa at 9:52 AM 8/13/2007
Old Aug 13, 2007 | 05:51 AM
h2bv8killa's Avatar
Default Re: need help!!!! h2b swap (h2bv8killa)
bump for a fat kid that needs a ride!!!
Old Aug 13, 2007 | 06:01 AM
egsleepercivic's Avatar
fix your tps and you should see an improvement
Old Aug 13, 2007 | 07:18 AM
h2bv8killa's Avatar
Default Re: (egsleepercivic)
so i replaced it with a used one and reset the ecu and the code was still there. i sure hope they were both bad
Old Aug 13, 2007 | 07:56 AM
did you set it so that its close to .5v closed throttle and 4.5v wide open, also souble check your wiring to make sure everything is secure
gl
Old Aug 13, 2007 | 10:13 AM
h2bv8killa's Avatar
i'll check that. thnx. im running open header too would that cause my compression to decrease in any noticable way?
Old Aug 13, 2007 | 10:19 AM
builthatch's Avatar
MiG-21 superfan
Default Re: (h2bv8killa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2bv8killa &raquo;</TD></TR><TR><TD CLASS="quote">i'll check that. thnx. im running open header too would that cause my compression to decrease in any noticable way?</TD></TR></TABLE>
yeah, check the wiring and make sure that it's set to spec.
the open header will hurt your low rpm performance a bit, but as it opens up it should perform well.
i believe the TPS issue has put you in limp mode. the engine has pulled timing, dumped fuel and just overall protecting itself from getting hurt.
Old Aug 13, 2007 | 01:19 PM
h2bv8killa's Avatar
Default Re: (builthatch)
okay i checked the voltage. its reading 0 at closed throttle and 1.56 at wot. so what could cause this? ive got 5 volts coming into the plug through the yellow wire. could it be the plug itself?
Old Aug 13, 2007 | 03:45 PM
h2bv8killa's Avatar
up to the top. need this problem taken care of quick guys!!!
Old Aug 13, 2007 | 04:46 PM
loosen the screws on the tps an turn to see if you can chiange the readings
Old Aug 13, 2007 | 05:24 PM
h2bv8killa's Avatar
i tried that and the most i could get out of was 1.5 at WOT
Old Aug 13, 2007 | 05:35 PM
builthatch's Avatar
MiG-21 superfan
that tps is beat then...that's insane to not be able to get more...
Old Aug 13, 2007 | 05:45 PM
h2bv8killa's Avatar
agreed...i'll try another tps i guess. this bamboozles me...
Old Aug 14, 2007 | 07:14 AM
h2bv8killa's Avatar
bump. has anyone had this problem???
Old Aug 15, 2007 | 10:24 AM
h2bv8killa's Avatar
AFTERNOON BUMP. waffles are cool
Old Aug 15, 2007 | 12:35 PM
turtleman321's Avatar
no need to bump this thats your problem your tps i done. .45 volts at closed and 4.5 at wot
Old Aug 15, 2007 | 02:08 PM
builthatch's Avatar
MiG-21 superfan
Default Re: (turtleman321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtleman321 &raquo;</TD></TR><TR><TD CLASS="quote">no need to bump this</TD></TR></TABLE>
exactly what i was thinking. nothing we can say will make that TPS replace itself haha
Old Aug 16, 2007 | 02:15 AM
h2bv8killa's Avatar
yeah but ive tried three different ones and it is doing the same exact thing. ive gotta new dh racing TB and tps on the way so its cool
Old Aug 16, 2007 | 01:57 PM
King V's Avatar
I would check your wires(nobody seems to do that at all on these threads, they just keep swapping parts). If three different TPS's all failed, sounds like a wiring issue, not a component issue.
Old Aug 17, 2007 | 08:24 AM
h2bv8killa's Avatar
Default Re: (200kCivicSI)
i tested the yellow power wire and its good. anyone know which pinout the tps is?
Old Aug 17, 2007 | 08:56 AM
builthatch's Avatar
MiG-21 superfan
d11 is TPS
http://technet.ff-squad.com/wiring.obd1.htm
d601
Jul 29, 2011 05:04 PM
superhatchbackbros
Apr 2, 2008 06:22 AM
chas92h22
Dec 31, 2007 05:20 PM
93accdcivickla
Apr 29, 2007 09:45 PM
hondasport2000
Apr 24, 2006 11:12 AM
