Piston To Wall Clearence Confirmation
Old Aug 13, 2007 | 02:53 PM
5_Lug_B's Avatar
* B A N N E D *
Default Piston To Wall Clearence Confirmation
Ok, I have my 81mm GSR and I removed the pistons and rods (time for a rebuild ) I know I need to rehone the cylinder walls so I went and purchased some 81.25mm P30 Pistons to bump up the compression on it. Now what is the ideal piston to wall clearence for this set up? Ive been told it is .001 , Is this correct?
Old Aug 13, 2007 | 03:41 PM
JRTegman987's Avatar
Default Re: Piston To Wall Clearence Confirmation (5_Lug_B)
you going forced induction at all? the higher heat can call for bigger clearances depending on the expansion rates of various pistons...
thats all i know lol but just so someone can help u sooner
Old Aug 13, 2007 | 04:03 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: Piston To Wall Clearence Confirmation (JRTegman987)
Thanks for the help....tttttt
Old Aug 13, 2007 | 06:04 PM
5_Lug_B's Avatar
* B A N N E D *
anybody?
Old Aug 13, 2007 | 06:12 PM
slowcivic2k's Avatar
Best clearance I've seen with a factory piston is .0008"-.001" they don't like to see much more than .002" or else sealing/oil consumption becomes and issue, any tighter, and you might be metal on metal. Compression numbers are best with this clearance as I've seen.
You can also form your own conclusions, factory spec is .0004" to .0016" and service limit being .002".
Old Aug 13, 2007 | 10:14 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: Piston To Wall Clearence Confirmation (slowcivic2k)
Thanks, so exactly what would you reccomend between the .0008"-.001" ?
Old Aug 14, 2007 | 11:52 AM
5_Lug_B's Avatar
* B A N N E D *
Old Aug 14, 2007 | 12:36 PM
With a factory slug I aim for .001".
Old Aug 14, 2007 | 12:43 PM
lsturbo*'s Avatar
I assume you are talking .001 radial? (or .002 diametral)
Old Aug 14, 2007 | 02:05 PM
BILLETGRIP's Avatar
Default Re: (lsturbo*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsturbo* &raquo;</TD></TR><TR><TD CLASS="quote">I assume you are talking .001 radial? (or .002 diametral)</TD></TR></TABLE>
lol someones TRYING to be a smartass!!!!!!
Old Aug 14, 2007 | 05:29 PM
lsturbo*'s Avatar
Default Re: (BILLETGRIP)
Actually i was serious....i am putting my LS together and just got my block back with new pistons and want to take a measurment.
Old Aug 14, 2007 | 05:51 PM
BILLETGRIP's Avatar
think of it as you would for the clearance call-out on anything else. not per side but overall.
fjt
Jun 9, 2010 06:18 AM
Bspec18
Oct 4, 2005 03:11 PM
B16Civic93
Apr 14, 2005 06:38 PM
Mark
Aug 26, 2003 09:36 PM
greengangsta
Mar 18, 2002 07:23 PM
