Rusted cam still fixable and good to use??
Old Aug 6, 2007 | 02:45 AM
methos713's Avatar
Default Rusted cam still fixable and good to use??
Well was cleaning up the storage and found a ZC cam that I remember I got from a sohc civic from pick-n-pull. Had it stored, forgot about it, and now its rusted. I sprayed some wd-40, just to see what it would do. Just want to know if it is still fixable and usable? Here are some pics.
Old Aug 6, 2007 | 10:03 AM
SOHCD16y8's Avatar
Sand off the rust with some 1000 grit and you should be good to go.
Old Aug 6, 2007 | 10:34 AM
crawlin's Avatar
Default Re: (SOHCD16y8)
try just rubbing some off or sand very carefully thats not a surface you want out of round
Old Aug 6, 2007 | 11:44 AM
methos713's Avatar
Default Re: (crawlin)
so if I sand it, jus try to get as much out as possible?
Old Aug 6, 2007 | 11:47 AM
SOHCD16y8's Avatar
My guess is that it is just a light surface rust and will only take a little bit of sanding to get it off. Just use 1000 grit and you will be fine.
Old Aug 6, 2007 | 01:04 PM
crawlin's Avatar
just be careful and make sure to keep circling and not stay in one spot
Old Aug 6, 2007 | 05:20 PM
VRD^sam's Avatar
my skunk2 cams were sitting for 3months started to rust i spray'd WD40 wiped it off and sanded it down with fine sandpaper
Justin Olson
Welding / Fabrication
20
Dec 21, 2007 06:19 AM
sundownz
Feb 9, 2007 10:07 AM
fbw2003
Apr 5, 2006 05:28 PM
dornon13
Aug 17, 2004 06:25 PM
