ECU
Old Aug 10, 2007 | 07:02 AM
HondamanXxX's Avatar
GO GIANTS!
Default ECU
I have a OBD2 JDM GSR into a EJ8, 98 ex. I am unsure what ECU to use. Keep in mind that later I will be puting Neptune in it. Should I go with a OBD1 ECU p28?
I am very clueless when it comes to ECU's. I would like to stay OBD2 also.
Old Aug 10, 2007 | 10:27 PM
mtber's Avatar
Default Re: ECU (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">I have a OBD2 JDM GSR into a EJ8, 98 ex. I am unsure what ECU to use. Keep in mind that later I will be puting Neptune in it. Should I go with a OBD1 ECU p28?
I am very clueless when it comes to ECU's. I would like to stay OBD2 also. </TD></TR></TABLE>
Neptune/Hondata/Crome etc.. only support obd1 ecus. You will have to use a obd2 to obd1 jumper harness if your car is obd2 (Plug & Play) along with a obd1 ecu.
Concerning what obd1 ecu to use, you can use a bunch of different models. I recommend you read over http://www.phearable.net/tech/....html its a good read
Dcaustin156
Jan 9, 2014 06:56 AM
egbaby
Mar 1, 2008 06:52 AM
HondamanXxX
Aug 12, 2007 07:30 PM
superfuji57
Mar 21, 2003 09:19 AM
