WTF sensor is this???? I NEED IT!
Old Aug 7, 2007 | 08:52 PM
JDMJNKY's Avatar
Default WTF sensor is this???? I NEED IT! AGAIN!
need this again! FAAAAAWWWWWWKKKKKKK! I guess it's called a "thermo valve", but honda doesn't carry it????
[NEED MORE INFO ON THIS PART, AN WHERE TO GET IT? HOW MUCH IT COSTS.......ASAP PLEASE!!!!
<FONT SIZE="5">The part im looking for is in the bottom left marked # 24</FONT>
Old Aug 8, 2007 | 01:05 AM
Mista Bone's Avatar
D Tranny Guru
What year make and model FORD?
Old Aug 8, 2007 | 06:27 AM
JDMJNKY's Avatar
Default Re: (Mista Bone)
Mista Bone/Transzex its for a 1996 honda civic ex, I was told it once was a thermo valve, but every google search showed some type of solenoid which is no where close to! This sensor is located just below the manifold on the coolant pipe that runs behind the block, and is attached to the thermostat housing. This is only found on 96-98 ex models
Old Aug 8, 2007 | 01:09 PM
Wes V's Avatar
Default Re: (JDMJNKY)
Interesting!!
I went to the Majestic web site and they have the same photo (as they should) and yet don't list the part.
I'd recommend that you print out the diagram and take it to your local dealer. On the assumption that it's on 98 EX's, that's only 9 years old and they should have some form of listing.
If you have the factory manual (helm's manual), you could look it up there. You may have to look in the electrical section as I think those "C" call-outs are electrical connectors.
I've no idea where "soul" california is, but there has to be a local "honda/acura" junk yard that can help you out finding another. (but then again, they may want to sell you a complete engine.
In a worst case, call Hasport and ask them if you can send them the photo to see if they know what it is and where you can get one.
Why do you need to replace it?
Wes
Old Aug 8, 2007 | 01:52 PM
JDMJNKY's Avatar
Default Re: (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">
Wes</TD></TR></TABLE>
I broke it, just after the leg that t's off. for the 2nd time, once on my friends swap and now on mine.
Old Aug 8, 2007 | 01:53 PM
Relic1's Avatar
the reason why they couldn't find it for your car is because that part is not used on the 96 EX. (you should have the other thermostat housing)
it's used in the OBD2b versions...
#24 = Valve, Air Assist Solinoid - 36281-P2P-A01
Old Aug 8, 2007 | 01:56 PM
JDMJNKY's Avatar
Default Re: WTF sensor is this???? I NEED IT! AGAIN! (JDMJNKY)
I wonder if i can just eliminate it completely? Because one hose that was connected I blocked off when I dropped in a 00 ex motor....it was not needed.
Old Aug 8, 2007 | 02:59 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">when I dropped in a 00 ex motor</TD></TR></TABLE>
see that peice of info right there would have saved you (and us) a lot of problems.
when looking for engine parts, you have to ask for parts to the engine you have not the chassis.
how do you know the one hose was not needed? (asking not knowing where those hoses go)
Old Aug 8, 2007 | 03:29 PM
JDMJNKY's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">the reason why they couldn't find it for your car is because that part is not used on the 96 EX. (you should have the other thermostat housing)
#24 = Valve, Air Assist Solinoid - 36281-P2P-A01</TD></TR></TABLE>
Why would it be on my car? I previousily had a 99 ex motor in the car as a replacement for the original engine? Should I swap housings?
Old Aug 8, 2007 | 04:11 PM
JDMJNKY's Avatar
Default Re: WTF sensor is this???? I NEED IT! AGAIN! (Relic1)
how do you know the one hose was not needed? (asking not knowing where those hoses go)</TD></TR></TABLE>
That one hose was blocked of by my buddy who helped me the first time, he said it wasn't needed.
Old Aug 9, 2007 | 07:34 AM
Relic1's Avatar
Why would it be on my car? I previousily had a 99 ex motor in the car as a replacement for the original engine? Should I swap housings?</TD></TR></TABLE>
you have a 96 EX that had a 99 Y8 which now has a 00 Y8?
depending on what those hoses do you may not need them. I'll try to figure out what they do at lunch today.
Old Aug 9, 2007 | 10:58 AM
JDMJNKY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">you have a 96 EX that had a 99 Y8 which now has a 00 Y8?
depending on what those hoses do you may not need them. I'll try to figure out what they do at lunch today.</TD></TR></TABLE>
It adds vaccum when the coolant reaches a certain temp. Don't know where to? I bypassed it yesterday! I know one location of the hose was from the manifold to the sensor, then another connection was a hose previously blocked off by my friend, who's a certified honda tech. So basically I put the old housing on from a 00 dx and capped off the manifold port.
spiritofjosh
Honda Civic (2001 - 2005)
May 14, 2019 09:09 AM
336civic
Jul 21, 2016 01:14 AM
stillb23
Nov 15, 2009 02:57 PM
civcexcoupeblack
Jun 20, 2003 08:42 PM
