ignition timing, advance all the way, need input please,
Old Aug 16, 2007 | 01:36 PM
civic j's Avatar
Default ignition timing, advance all the way, need input please,
right h-t, so i finally get around to check out my ignition timing today, to my suprise it was set at 0degree's,
i get the timing gun out, bypass the jumper, advance the distrubutor, but the problem is im still about 5-10 degree's out from where i should be at 16d with the dist advanced all the way,
basically its stll inbetween 0-14 degree's
what do i do next?!
thanks H-T...
Old Aug 16, 2007 | 04:07 PM
stumpyf4's Avatar
Default Re: ignition timing, advance all the way, need input please, (civic j)
Make sure your timing belt is on right. Possibly skipped a tooth.
Old Aug 16, 2007 | 08:18 PM
Padawan's Avatar
Darth ModerVader
Are you certain you're using the timing light correctly? I seems doubtful that the timing was set at TDC. How was the car running?
Old Aug 17, 2007 | 08:10 AM
thesmogman's Avatar
Default Re: ignition timing, advance all the way, need input please, (Padawan)
Do you have the timing light with the advance?
If so set it to 16 degrees and the timing mark(white) should be lining up.
If you leave the light set to 0 degrees you should see the two red marks with a notch in the middle. It should be lined up with the notch in the middle.
If you got it right then you are off a tooth.
turbo-crx
May 18, 2008 02:13 PM
sikek1
Apr 28, 2008 05:49 AM
handa
Oct 24, 2004 08:27 AM
JDM 007
Aug 23, 2002 09:11 AM
rioninja
Aug 4, 2001 05:48 AM
