How Much for a Tune
Old Aug 17, 2007 | 10:11 AM
CALC!_JUST_du_IT!'s Avatar
Default How Much for a Tune
I'm finishing up a high compression (~11.0:1) build on my d16y8. This is my build, for the most part:
Fully built head (pnp, crower st2 cam springs & retainers, skunk2 valves, arp studs, full overhaul)
Built block (eagle h-beam rods, srp high cr pistons, reman crank, full overhaul)
Cometic 0.027" Head Gasket (stock was 0.037")
All the bolt ons (including 70mm tb, skunk2 im, dc header, trust/rs-r cat back, aem v2, etc)
ACT Clutch and Flywheel (I think 11lbs)
Accel 260cc/min Injectors (stock is 240cc/min)
AEM fpr and Fuel Rail (fuel pressure close to stock)
AEM adjustable cam gear
etc...
I'm looking to get a tune as soon as I'm done breaking in the motor. I will need the ecu tuned, the fpr adjusted, and the cam timing set. How long should this take at a dyno shop? I live in the SF Bay Area, and most shops around here charge around $180-$200/hr!!! Is that high?
I need your feedback on this so I can plan for the tune financially. I know it has to be done, but I'll have to wait on it for awhile if it's gonna be more than $400.
How many hours should I expect to be charged for?
Old Aug 17, 2007 | 02:41 PM
Lubo_25's Avatar
Default Re: How Much for a Tune (CALC!_JUST_du_IT!)
i live in canada and the std. rate around here is 150$ CDN on average so yea that seems to be a little high but hey if the shop is ****** awesome you pay up!
Old Aug 18, 2007 | 12:42 AM
OC Geezer's Avatar
Default Re: How Much for a Tune (Lubo_25)
sounds kinda high. It takes about 2-4 hours +/- depending on what they're gonna do and how precise they are.
cmasonrun
39
Jan 2, 2008 09:17 AM
CALC!_JUST_du_IT!
21
Aug 18, 2007 10:14 PM
b18blackek
46
Jun 15, 2005 07:15 AM
TGUNNER
61
Dec 15, 2004 10:13 AM
meanEG
25
Jun 17, 2004 05:32 AM
