Oil Burning Quite Quickly
Old Aug 14, 2007 | 07:41 AM
Probot's Avatar
Default Oil Burning Quite Quickly
about 2 months ago i replaced my blown Y8 motor with another Y8, last week oil light flickered for not even a second - check the oil and it is bone dry. car isn't leaking anywhere, it's not smoking. i know i should be checking the oil regularly but i was just going to change the oil cause its been about 3500 since it got changed last. any thoughts even though i know it can be a ton of things internally that can cause oil to burn..but something is causing almost 4 quarts of oil to burn off really damn quick.
Old Aug 14, 2007 | 09:05 AM
hatchling37's Avatar
Default Re: Oil Burning Quite Quickly (Probot)
You might not be able to see it burning while you're driving. I would suggest a compression test and maybe leakdown and go from there.
Old Aug 14, 2007 | 09:13 AM
Probot's Avatar
Default Re: Oil Burning Quite Quickly (hatchling37)
yea good call, dont know why i didnt think of that but hey thats why im glad i ask questions. that'll tell me if the problem lies within the pistons/rings right?
whatever it is, its gonna suck..i really dont want to pay to have it fixed
Old Aug 14, 2007 | 09:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote"> that'll tell me if the problem lies within the pistons/rings right?
Exactly. Also check your plugs to see if they're fouled.
Yeah, that could get expensive, sorry.
Old Aug 14, 2007 | 10:07 AM
Probot's Avatar
thanks dude, i appreciate it.
booo
Old Aug 14, 2007 | 11:24 AM
MeanGreenMachine's Avatar
i did a comp test on the gf's car and the #'s were good, the #'s were consistent in all 4 cylinders, and the plugs were not fouled at all, but yet oil was still being lost little by little, so when the clutch went out, i got it replaced with a new flywheel and clutch. when i pulled the old flywheel off i noticed that the rear main oil seal was bad and oil was leaking from that particular spot. im going to get that rear main oil seal replaced and hope that it fixes the oil loss problem....
Old Aug 14, 2007 | 08:05 PM
Probot's Avatar
Default Re: Oil Burning Quite Quickly (MeanGreenMachine)
definitely let me know how that works out
Old Aug 23, 2007 | 10:10 AM
Probot's Avatar
changed plugs last week...they were black as could be
Old Aug 23, 2007 | 10:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote">changed plugs last week...they were black as could be</TD></TR></TABLE>
and when u put new plugs in it ran............................................... ......
Old Aug 23, 2007 | 12:46 PM
Probot's Avatar
ran the same....same day changed the oil, 3.5 qts...checked it today...less than 2 qts in the car...going to take my car to get a compression and leakdown test this weekend.
Probot
27
Aug 24, 2007 01:15 PM
allicedout
May 21, 2004 01:33 PM
silvlude
Jul 31, 2003 05:12 PM
2SlowAccord
Jul 2, 2003 03:24 PM
LB CRX
Oct 20, 2002 08:14 PM
