Wiring Question
Old Aug 18, 2007 | 07:08 AM
LSEGHATCH's Avatar
Default Wiring Question
When testing wires for an application that requires x voltage or x ohms, do you do this with the car running and battery fully charged or can you do it with the ignition switched to auxillary and a fully charged battery?
Old Aug 18, 2007 | 08:26 AM
King V's Avatar
Default Re: Wiring Question (LSEGHATCH)
Voltage drops are the easies way to tell your wires condition. You should be able to get away with testing certain circuits Key on, engine off. Regardless, a fully charged battery is a good idea.
Old Aug 18, 2007 | 09:13 PM
slowcivic2k's Avatar
When you do a voltage test, you always measure the battery voltage first, as it will vary slightly, most diagrams state that you must have battery voltage at a certain point, not just 12.6V but whatever the battery is putting out.
Resistance checks are always done with the circuit disconnected without power.
PoisonRitualz
Oct 24, 2018 02:20 PM
White V6
Jul 1, 2005 09:11 PM
The_In_Kid
Oct 9, 2002 04:27 PM
