Removal of rust from the header
Old Aug 12, 2007 | 04:37 PM
GSR2001's Avatar
Default Removal of rust from the header
Don't know where to for sure post this, search but didn't find anything about this issue.
So the question is how to get rid of the rust on the DC header without having to deal with it every few months.
I heard that if you remove the ceramic coating it gets worst.
Old Aug 12, 2007 | 04:55 PM
Padawan's Avatar
Darth ModerVader
Default Re: Removal of rust from the header (GSR2001)
Send it to be professionally coated inside and out.
Old Aug 13, 2007 | 05:34 AM
Crispy's Avatar
Default Re: Removal of rust from the header (Padawan)
If you want to do it in your garage I personally would hit it with a wire brush attached to a drill, then spray it with high temp "thermal?" paint. There was a post about that a while back but I forget now. I wonder if they make high temp etchant primer : /
Otherwise I'd assume it will just start rusting again unless you can get ALL the rust off...which would be hard with a wire brush.
Or, stick it in a parts washer.
Or wrap it with header tape.
I'd like some more ideas on this too, I've got the same problem.
Old Aug 13, 2007 | 08:46 AM
4g hatch's Avatar
sand blasted, then powder coated
Old Aug 13, 2007 | 09:54 AM
Katman's Avatar
No joke.
soak the rusted areas in COCA COLA for like 30min.
Coke eats up/disolves rust.
And to think we drink that stuff!
Old Aug 13, 2007 | 10:22 AM
builthatch's Avatar
MiG-21 superfan
Default Re: (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">No joke.
And to think we drink that stuff!</TD></TR></TABLE>
you can also use coke to anodize titanium parts for RC cars. all you need is coke and an adjustable DC power supply.
at any rate, since it might be hard to submerge an entire header in cola, i'd send it to Swain in NY and get their white lightning coating. they will prep it for you as far as i know. it's a hair expensive but it's cheaper than getting a new header and it'll last indefinitely. it's not a ceramic paint type coating like jet hot and the rest.
Old Aug 13, 2007 | 11:11 AM
4g hatch's Avatar
And to think we drink that stuff![/QUOTE]
yeah i drink it every day
Old Aug 13, 2007 | 03:51 PM
GSR2001's Avatar
Thanks for the replies!!!!!!
Old Aug 13, 2007 | 08:07 PM
Katman's Avatar
Default Re: (builthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch &raquo;</TD></TR><TR><TD CLASS="quote">
hm...interesting
Vtakkk
May 14, 2006 07:12 PM
HXvtec
Apr 11, 2006 04:41 PM
iuseamsoil
Mar 9, 2004 08:49 AM
EG_93Civic
Aug 21, 2003 08:18 PM
cityofcaterpillars
18
Jun 13, 2003 08:51 AM
