b16 header on b18
Old Sep 10, 2002 | 01:16 PM
TRENDSETTLER's Avatar
Default b16 header on b18
anybody know if an apex'i gt spec header off of a b16a2 will fit on a b18c1 any help would be appreciated
thanks
Old Sep 10, 2002 | 01:21 PM
carl_aka_carlos's Avatar
Default Re: b16 header on b18 (TRENDSETTLER)
should fit....all B-series exhaust ports are the same....just a matter of whether it will bolt to the cat (it may be too short or long)
Old Sep 10, 2002 | 01:23 PM
Default Re: b16 header on b18 (carl_aka_carlos)
yeah i know i have to get a shorter race cat cause the factory cat is too long i was just wondering cause the guy im buyin from said it might not clear the oil pan...thanks for the info
Old Nov 11, 2002 | 06:20 PM
SpoonSportsJunkie's Avatar
On that note, Should the stock iron manifold off a B18B fit a B16a cylinder head? And should it reach to the Eg civic's stock Catalytic converter placement?
Old Nov 11, 2002 | 09:45 PM
GZR4DR's Avatar
Default Re: b16 header on b18 (SpoonFanatic)
An LS header will fit a B16A motor. However chances are that the cat placement will be in a different location. Good news is the bolts line up, all you have to do is extend the B pipe.
hefftone79
11
May 13, 2011 03:13 PM
dblkack30
Mar 30, 2008 09:28 PM
DM95eg
16
Jun 21, 2005 08:32 AM
WangChung
Feb 21, 2003 06:58 PM
