code 14?
Old Sep 12, 2002 | 09:44 AM
TheOne's Avatar
Default code 14?
can anybody tell me what this code is for, on a 96 integra gs-r? thanks
Old Sep 12, 2002 | 09:49 AM
FLIPboi's Avatar
Default Re: code 14? (TheOne)
ECU Error Codes
By: Brian Cummiskey on 2002-03-22 17:17:18
Here's a handy chart for pulling your ECU codes. Pulling the code is a fairly easy process.
For 92+ Honda's and 94+ Acura's:
Before you can start reading the CEL (check engine light) in your dash, you need to 'jump' your ecu. Here's how.
Located the factory two-pin connector of brown and black wires near the ECU on Civics del Sols and Integra's, or behind the center console for Preludes and Accords. Pull that 2-pin out of the main harness. Using a wire or paper clip as a jumper, connect the outputs of the harness together, so that the black wire and the brown wire make a circuit. Once this is jumped together, the dash will start the light show, so its a good idea to jump first, then turn to on.
For 88-91 Honda's and 86-93 Acura's:
The ECU's on these cars actually have a neat little window right on the computer case. No need to jump here- just turn it to on, and watch it right there through that window.
For both steps above, the output will be in a Morse code style of long and short lights. For example, 2 long, pause, 3 short is 23.
0 ECU 43 FUEL SUPPLY SYSTEM
1 OXYGEN CONTENT 45 SYSTEM TOO RICH OR LEAN
3 MAP SENSOR 48 PRIMARY HEATED 02 SENSOR
5 MAP SENSOR 54 CRANKSHAFT SPEED
6 CRANK ANGLE 61 PRIMARY 02 SENSOR CIRCUIT
7 THROTTLE ANGLE 63 SECONDARY 02 SENSOR CIRCUIT
8 TDC POSITION 67 CATALYST SYSTEM
9 No 1 CYLINDER POSITION 70 AUTOMATIC TRANSAXLE
12 EXHAUST GAS RECIRCULATION 71-74 RANDOM MISFIRE
23 KNOCK SENSOR 80 EXHAUST GAS RECIRCULATION
13 ATMOSPHERE PRESSURE 86 ENGINE COOLANT TEMP. CIRCUIT
14 ELECTRONIC AIR CONTROL 90 EVAPORATIVE EMISSION CONTROL SYSTEM LEAK DETECTED
15 IGNITION OUTPUT CONTROL 91 FUEL TANK PRESSURE CIRCUIT
16 FUEL INJECTOR 92 EVAPORATIVE EMISSION CONTROL SYSTEM INSUFFICIENT
17 VEHICLE SPEED SENSOR 41 02 SENSOR HEATER
20 ELECTRONIC LOAD DETECTOR 63 INTAKE AIR TEMP
Old Sep 12, 2002 | 10:04 AM
Ferrell's Avatar
Default Re: code 14? (FLIPboi)
Idle Control System Malfunction
Old Sep 12, 2002 | 10:17 AM
salbaje's Avatar
iac on the back of the intake manifold. does your idle go up and down??
Old Sep 12, 2002 | 10:39 AM
TheOne's Avatar
Default Re: code 14? (salbaje)
yes it does go up and down, but when the check engine light comes on all it does is idle really low, around 600or 500rpms
Old Sep 12, 2002 | 10:41 AM
TheOne's Avatar
would it make any difference that I have a bi6 head and intake manifold
Old Sep 15, 2002 | 02:57 PM
RockDawg_GSR's Avatar
http://tech.hybridgarage.com/tech/codes.html
JDMlyfestyle
588
Nov 3, 2022 12:37 PM
Loyalhondahaver
14
Oct 18, 2013 11:52 AM
doctorake
Mar 25, 2012 08:01 AM
ceLtic*
Apr 15, 2005 02:38 PM
USDMEH2
Oct 7, 2002 10:24 PM
