Cam seal broken?
Old Sep 8, 2002 | 07:45 PM
Brolli007's Avatar
Default Cam seal broken?
I have oil leaking from the feft side of my b18 motor from a round black plug near the top under the valve cover. Is that likely to be the cam seal? If so, besided the seal, what will I need to fix it or what else could it be?
Old Sep 9, 2002 | 06:27 AM
b19coupe's Avatar
Default Re: Cam seal broken? (Brolli007)
By left do you mean the driver's side? Or do you mean the the side of the engine with the distributor? It sounds like you are describing the cam plug which is on the distributor side of the engine. If it's the cam plug, it's no big deal.Replace the cam plug and torque the 10mm bolts to 7 ft-lbs. You might want to have your valves adjusted at the same time if they have not been adjusted for awhile.
fortworthmatt
Honda CR-V & Element
Sep 7, 2015 09:55 AM
mickey513
Jan 30, 2015 09:32 AM
Mr.Luder
Sep 15, 2006 06:19 AM
pancake
Feb 10, 2005 01:50 PM
mickey513
Aug 8, 2004 06:39 PM
