Another Hondata question
Old Sep 11, 2002 | 09:26 PM
B18Flip's Avatar
Default Another Hondata question
I was just wondering if it was advisable to install someone elses dyno tuned hondata 3b in my car. We both have the same set up b18c w/ jrsc. Although, his was running on a p28 ecu and i have a p72. PLS HELP
Old Sep 12, 2002 | 05:41 AM
GruvyTune's Avatar
New User
Default Re: Another Hondata question (B18Flip)
only if the ecus are the same can you do that. the compensation tables are different between the ecus. i run a p72 ecu but have had to run a p28 based rom in mine due to hesitation problems. the fuel maps look a bit different after tuning between the two if you swap the ecus. better get it fine tuned just to make sure. you will be alright for a little while like that though
thirsk66
Feb 2, 2015 10:41 AM
jdm4show
May 22, 2004 11:51 PM
TerribleOne
Feb 9, 2004 03:51 PM
Nextelbuddy
Jul 24, 2003 10:43 AM
StinkyTofu
Dec 29, 2002 11:51 PM
