VSS...& Code 17
Old Sep 10, 2002 | 03:09 PM
CivicEK.PDX's Avatar
Default VSS...& Code 17
OK...well I am getting code 17...VSS ****-up. It just started. i would notcie about 1 week before it threw the code that the speedo would jump once ina while then it became more frequent. Now the speedo is dead. I replaced the ECM and that is not the problem. I replaced the VSS and that is not the problem. The cluster works fine. The tach works too. Wuold the tach not work if it was a mechanical rpoblem? I am thinking that it is electrical somewhere. Any help appreciated. Thanks
Old Sep 10, 2002 | 07:27 PM
Default Re: VSS...& Code 17 (CivicEK.PDX)
ttt....
Old Sep 11, 2002 | 06:37 AM
Spade's Avatar
Suggest helms and trouble shooting steps involved with the VSS. You may have gotten a bad VSS.
Old Sep 11, 2002 | 08:39 AM
Austin's Avatar
Default Re: VSS...& Code 17 (Spade)
You have a fuse blown under the dash...most likely from your secondary O2 sensor wires shorting out. Check under the dash for the fuse that's also the alternator/charging indicator light...can't remember what else it is, but that's the fuse that was blown on my car.
Austin
Old Sep 11, 2002 | 11:24 AM
sackdz's Avatar
Default Re: VSS...& Code 17 (Austin)
Austin
When that fuse blew (2ndary O2) on my car it wouldn't run... on the same circuit as the PGM-FI Main relay I believe... but that is on a 3g teg. If it started acting up and then finally quit I would take a look at the plug + wiring ON the VSS since you already replaced the VSS.
Old Sep 11, 2002 | 11:27 AM
Checked those fuses...no luck. I have replaced the vss. I am gonna tesk per helms. And I need to check the back of the cluster. Any other suggestions appreciated. Thanks
Old Sep 11, 2002 | 12:04 PM
Mista Bone's Avatar
D Tranny Guru
clean the VSS connector at the tranny, won't believe the crud that gets in there.
Old Sep 11, 2002 | 02:33 PM
Default Re: VSS...& Code 17 (Mista Bone)
I did I replaced it with a clean *** one. It satrted to work again today. then I hit some bumps and it went wacko. i am thinking it is the wires. You know how their a pain in the ***....to always pull the plug by the wires. I am gonna cut it and solder on a new connection. Thanks
Old Sep 11, 2002 | 03:07 PM
fowler!'s Avatar
I had the same problem. Especially when it was damp out. Most likely the plug on the harness.
Clean it off once in a while..
Old Sep 11, 2002 | 06:04 PM
Default Re: VSS...& Code 17 (fowler)
It was the wires. The middle one got pulled out so the connector wasnt touching the pin. I have an extr harness that i am using for plugs so I sniped and soldered it...Works perfect now.
Old Sep 13, 2002 | 03:23 AM
Mista Bone's Avatar
D Tranny Guru
who is your tranny daddy?
Only reason I know, I dropped a tranny once without unhooking the VSS connnector. I ripped the pins out of the plug. Did a splice job, all has been fine for 2-3 years now.
Old Sep 14, 2002 | 10:47 PM
ruthless013's Avatar
you guys may have saved my ****. have been having the psycho-speedo-needle problem for about 2 weeks now, and got my first CEL tonight. when i pulled the sensor today, the connector was crudded up with blue crap, figuring coolant spilled during engine r/r. i will mess with the harness/wires/connectors more next time i can get to it and see if that doesn't fix it.
how were you able to get in there and solder ****? barely any slack on the ecu side of the harness, unless there's more from underneath. hmm.
glad i used the search.
Old Sep 14, 2002 | 11:44 PM
r7's Avatar
r7
Default Re: VSS...& Code 17 (ruthless013)
check the back of the gauge cluster.. i had same problem. burnt circuit
Old Sep 16, 2002 | 03:33 AM
Mista Bone's Avatar
D Tranny Guru
I used "posi-locks" because I could not get in there with a iron. Wiring harness will be fixed right when/IF I pull the motor.
Old Feb 20, 2004 | 07:54 PM
LukeDanger's Avatar
save.
twiztid_989
34
Apr 24, 2009 12:01 PM
em1si
10
Sep 6, 2007 06:08 AM
RedEj8
Jun 19, 2006 09:00 PM
cjames235
Dec 27, 2003 06:17 AM
bgod
Jun 5, 2003 09:50 AM
