Pulling tranny apart, should clutch be replaced while I'm at it?
Old Sep 12, 2002 | 08:35 AM
Angry Joe's Avatar
Default Pulling tranny apart, should clutch be replaced while I'm at it?
I'm removing my transmission to investigate a bad throwout or pilot bearing. Some people have advised be to replace the pressure plate and clutch as well as turning down the flywheel as long as I have the tranny out.
The car has only 55K on it (although I learned to drive stick on this car) and the clutch shows no signs of slipping.
Should I bother? Also, can a flywheel be turned down on a manual lathe?
Old Sep 12, 2002 | 09:27 AM
92sleepR's Avatar
New User
Default Re: Pulling tranny apart, should clutch be replaced while I'm at it? (Angry Joe)
The flywheel will make more of a diference but sure, while you have it out is a good time to replace it. Taking the trans out with the engine in the car is a pain in the ***.
Mike
Old Sep 12, 2002 | 11:35 AM
3rdGteg's Avatar
Default Re: Pulling tranny apart, should clutch be replaced while I'm at it? (92sleepR)
I would keep it if it's still good cuz my clutch lasted 100,000 miles and on a '96 teg also. But it's always best to replace new parts so u wouldn't have to pull the whole thing apart again. Good Luck.
Old Sep 12, 2002 | 12:53 PM
B18EG6's Avatar
aww its not that bad.. i replaced my clutch with new pilot bearings and throw out bearing and thre it back on in a grand total of an hour...granted i had a lift to help, i guess that makes a difference
Old Sep 12, 2002 | 01:40 PM
Angry Joe's Avatar
Default Re: Pulling tranny apart, should clutch be replaced while I'm at it? (B18EG6)
Eh, what does a lift have that a gravel driveway and four jackstands doesn't?
Old Sep 12, 2002 | 08:57 PM
3rdGteg's Avatar
You not having to lay on your back and lift that tranny up. It's a b!tch trying to line up the tranny to the block on your back sometimes
Old Sep 12, 2002 | 09:07 PM
Angry Joe's Avatar
Default Re: Pulling tranny apart, should clutch be replaced while I'm at it? (3rdGteg)
I'll worry about taking it out now, putting it back I'll worry about it later.
m015094
Feb 19, 2007 11:44 AM
leewal
Sep 10, 2006 11:37 AM
CardDealer
Jun 6, 2004 03:10 PM
invboost
Nov 17, 2003 12:49 PM
eh-D
Jan 8, 2002 02:50 PM
