exhaust problem
Old Sep 10, 2002 | 03:36 PM
HatchBox's Avatar
Skoobie no more...
Default exhaust problem
ok on my civic i had the pipe ran custom ...and my exhaust is hitting the lower control arm ...when ever i hit a bump or anything..i did this b4 lowering my car i took it to the shop and they said they couldnt fix it...well can u give me any ideas
Old Sep 10, 2002 | 05:24 PM
dom93hatch's Avatar
Default Re: exhaust problem (xxkenyon419xx)
What car and what exhaust? Maybe all you need to d ois adjust the hangers a bit to give clearance.
Old Sep 10, 2002 | 05:31 PM
HatchBox's Avatar
Skoobie no more...
Default Re: exhaust problem (TYPE EG6)
there is no pep boy around (thank god) will autozone work?
btw its a 90 civic hatch std...and a maxspeed universal muffler
Old Sep 10, 2002 | 05:59 PM
HatchBox's Avatar
Skoobie no more...
ok i will give pep boys that...but most of the other stuff
Old Sep 10, 2002 | 07:02 PM
Shu's Avatar
Shu
Take it back where you had it installed and make them fix it. That is ridiculous. The piping over the control arm has to go up and around to give clearance for the control arm. You only have a 1/4" clearance between the control arm and piping. You can't just run the pipe straight back. They should know better.
What car is that? Is the picture flipped? Exhaust come out the left or right side of the car?
Lowering shouldn't matter. You should still have full suspsension travel.
Looks like you asked them to run the exhaust in a manner that it wasn't suppose to run. The piping should come over the right control arm and the muffler should be under the wheel well. It looks like there isn't enough room to mount that muffler in there like that. And I can't remember if there is room to loop the pipe up on the left side like you can on the right. Did they tell you it wasn't a good idea? If so then I guess you're stuck.
[Modified by Shu, 4:07 AM 9/11/2002]
Old Sep 11, 2002 | 11:20 AM
HatchBox's Avatar
Skoobie no more...
Default Re: exhaust problem (Shu)
well when i went there a year ago...we spent like 20 minutes trying to figure out how we could mount the muffler so it would accually fit..but that tis what we came up with. now i look back and think its dumb.. but when i got it done the car was at stock level and there was plenty of room ...so i just made a mistake in asking for it that way..guess i gotta go look around ...maybe set my car up like someones exhaust on here... idk who but the guy who ran it right under is gas thank and had the exhaust on a angle...
Emphyrio
Dec 10, 2018 08:02 AM
94eh2
11
May 5, 2009 07:24 PM
LilCivic04
Apr 28, 2004 06:54 PM
93JDMHONDA
Apr 8, 2004 02:49 AM
Eggman
Dec 6, 2001 08:32 AM
