B18 or B16 distributor???
Old Sep 8, 2002 | 07:53 PM
purpl7duece's Avatar
Default B18 or B16 distributor???
We just dropped in a 94 USDM GSR in my boys 90 civic si hatch. One person says run a 1st gen B16 dist and the other says GSR dist. we have heard different stories from everyone. what is the right one for the motor? peace
Old Sep 8, 2002 | 09:16 PM
Francois's Avatar
Default Re: B18 or B16 distributor??? (purpl7duece)
The question is more what ecu are you running?
That should answer your question.
OBD0-B16 1 gen.
OBD1-The GSR one.
Old Sep 8, 2002 | 09:17 PM
carcala's Avatar
what ecu are u guys running?? if its a pw0 or pr3 use the first gen b16. if u guys changed the wiring harness and are using obd-1 then u can use any b-series dist.
Old Sep 8, 2002 | 09:59 PM
Rocket's Avatar
Default Re: B18 or B16 distributor??? (carcala)
Good answer guys.
PR3 requires the B16 distributor. (16 tooth crank sensor)
P72 requires the GSR distributor. (24 tooth crank sensor).
ripperbone
Jun 24, 2007 02:19 PM
shingles
Jun 9, 2002 08:57 PM
EVOCELICA
May 25, 2002 08:14 AM
