question about my tach??
Old Sep 8, 2002 | 03:39 PM
91hatchcivic's Avatar
Default question about my tach??
ok,, is this right?? green wire gos to the distributor, black is ground, white goes to fues box, and where does RED go???
Old Sep 8, 2002 | 04:08 PM
Kamin's Avatar
Default Re: question about my tach?? (91hatchcivic)
power?
what the hell are you doing? you need to tell us.
odds are its for a 12v constant or ignition source
but i dont know, because we have no idea what your doing.
Old Sep 8, 2002 | 05:16 PM
Default Re: question about my tach?? (KAMiN)
o sorry, its for my auto-meter tach, tryin to make it work, also , when the cars off, the tach sits at around 1100, not 0, is the tach no good??
Old Sep 8, 2002 | 05:20 PM
99blackcivicSi's Avatar
red and white you can run to a power source, whit is illumination, red is power
Green is to read the Rpms (distributer or coil whatever)
and black to ground.
No your tach is fine mine does the same thing don't worry about it, i have a pro comp II so it will work fine.
Old Sep 8, 2002 | 10:03 PM
LuderCriS's Avatar
Default Re: question about my tach?? (99blackcivicSi)
that's normal
Old Sep 8, 2002 | 11:50 PM
ndogg's Avatar
Default Re: question about my tach?? (chanluder)
red = 12V when car is on
white = 12V when lights are on (possibly dash dimmer depending on the car)
black = Ground
Green = rpm signal
Old Sep 9, 2002 | 05:38 PM
Default Re: question about my tach?? (ndogg)
so can a just twist the white n red and run it to the same fuse or whatever
Old Sep 9, 2002 | 05:54 PM
B18EG6's Avatar
well if you twist the red and the white together, the light on the tach will always be on. theres a nice little thing honda added on the fuse box, pre wired for 12v constant, 12v ignition, 12v light....all that good stuff. what kind of car is it?
Old Sep 9, 2002 | 08:30 PM
Default Re: question about my tach?? (B18EG6)
91civic si, bought the car with the tach,i saw the red wire just hangin, gotta find out where to put it
Old Sep 10, 2002 | 01:42 AM
kinesistech's Avatar
The red wire gets ignition power. There are a couple extra pins above the fuses, one is ignition pwr. The green wire doesnt have to go all the way to the distributor. Its wired right behind the stock gauges, dont just have one ghetto wire running through the engine bay.
97turboteg
Mar 23, 2006 11:55 AM
HONDA_TYPE_R
Oct 31, 2004 01:45 PM
99blackcivicSi
Apr 18, 2004 01:44 PM
AllMotorBeast
Jun 11, 2003 10:13 PM
underpressure02
13
Feb 10, 2003 11:47 AM
