need help (broken bolt head)
Old Sep 9, 2002 | 01:23 PM
Doogie Howser's Avatar
Default need help (broken bolt head)
i broke the head of the strut fork pinch bolt and im wondering what i should do to get it out. I only have hand tools also no air tools. Im i going to have to bring it in somewhere, or is there something i can do
Old Sep 9, 2002 | 05:22 PM
BoostedAcura's Avatar
Default Re: need help (mlambrecht)
you can go to any auto part store and buy a bolt extractor kit. you use this kit to drill into the bolt and then pull it out with the bits included in the kit. its pretty simple and not too expensive. hope this helps
Old Sep 9, 2002 | 05:54 PM
Default Re: need help (BoostedAcura)
thanks for the help, right now though i have ran into the problem again of the damn axel stuck in the hub, last time i had to remove th knuck and have it pressed out....
Old Sep 9, 2002 | 06:30 PM
Spike2's Avatar
Heh i had the same problem on my rear suspension. I ended up cutting my stock shocks all up to get it off. Hopefully it is loose enough to get off with a bolt puller. Maybe try heating it with a blowtorch and then cooling it down with some WD-30 to loosen it up a bit. Hope that helps
Let me know if you need a stock knuckle. I have a set in my garage I can ship out this weekend. Looks like yours are a bit rusted.
[Modified by Bob Ross, 3:31 AM 9/10/2002]
Old Sep 9, 2002 | 06:32 PM
IlikeTODA's Avatar
The bit is called an EZ-OUT. I know sears has them. I would recommend using a center punch to keep the bit in the middle when you drill the hole.
Thanks, J
Old Sep 10, 2002 | 09:33 AM
rotten's Avatar
Was the bolt coming out when it broke or is the bolt seized?
If the bolt is seized you're going to have a pretty difficult time getting it out with an EZOut kit.
I'd suggest getting a friend to weld on another bolt onto the end of this one, and let some penetrating lubricant get back into the threads of the broken bolt and then give it another shot.
Old Sep 10, 2002 | 09:41 AM
Kataku2K3's Avatar
Default Re: need help (rotten)
Damn man, all your **** looks hella rusted. My friend had that same problem really bad on the rear suspension in his integra and i had to swap all the bushings because they were rusted to the arms. Hope you can get that bolt out.
Old Sep 10, 2002 | 12:09 PM
Default Re: need help (JDMspecEG6)
before i bought the car it was being driven in minnesota winters........they dont mix well with cars
terqui
Aug 12, 2013 03:38 AM
Racing_God
Suspension & Brakes
Oct 23, 2008 07:59 AM
Mfoehrkolb
Sep 22, 2007 03:22 PM
Serdar
Aug 18, 2006 11:39 PM
TheJediMex
Apr 14, 2003 08:23 PM
