CEL # 43...need a little help...
Old Sep 9, 2002 | 10:05 AM
Austin's Avatar
Default CEL # 43...need a little help...
This morning my car decided that it wanted to give me a good old code #43 as I was driving on my way to work. I also have a surging idle, the car will idle fine for a little while, then surge to 1400-->700-->1400-->700, you get the idea...then it may go back and idle just fine again.
I have a P28 based Hondata, HyTech header and exhaust, AEM FPR...
Code #43 - Fuel Supply System defective or malfunctioning fuel supply system
I was also told that it could be that my primary O2 sensor is malfunctioning and throwing me into open loop so that I'm only running off the program in the ECU...any other ideas?
Thanks,
Austin
Old Sep 9, 2002 | 11:41 AM
Sonny's Avatar
Default Re: CEL # 43...need a little help... (Austin)
The idle and the code 43 may not be related. Hunting idle is not uncommon with Hondata systems if the idle parameters (particulary the IACV duty cycle) has not been tuned.
AFA code 43...is your gas cap on tight?
BTW-That HyTech exhaust is BITCHIN! I read your posts in the Type R forum.
Sonny
Old Sep 9, 2002 | 12:10 PM
Austin's Avatar
Default Re: CEL # 43...need a little help... (Sonny)
Thanks Sonny...I'll have to ask Lawrence on that one.
It appears that both the hunting idle(which was never there before this weekends running of NHRA import drag) and the code 43 are intermittent problems...went to lunch and both of the problems weren't there, wonder why?
Austin
h23prelude
Jun 8, 2010 02:16 PM
reed857
29
Jul 26, 2009 10:57 AM
EFb18b
Jun 7, 2006 01:17 PM
c0nspire
Feb 23, 2006 02:09 PM
