help on ls vtec build
Old Sep 10, 2002 | 02:31 PM
ls_vtec_b18a1's Avatar
Default help on ls vtec build
ok i have a question that i hope someone can help me with. i dont know what head to get there are my choices
1. 90 first gen jdm pr3
2 sir 2 head
3 b16 u.s. not jdm older head
4 92 jdm 16a head
what head is the best for a ls vtec in a 91 integra thanks for any help
Old Sep 10, 2002 | 10:23 PM
3rdGteg's Avatar
Default Re: help on ls vtec build (ls_vtec_b18a1)
I'd prolly take the USDM b16 head from the 99-00 Si.
Old Sep 11, 2002 | 01:18 AM
salbaje's Avatar
what kind of internals do you ahve for yoru block??
Old Sep 11, 2002 | 09:36 AM
Kataku2K3's Avatar
Default Re: help on ls vtec build (salbaje)
I would go with a GSR head, wheather you use a stock bottom end or one with higher compression pistons you will automatically get a jump of 0.22:1 just from the fact that a GSR's combustion chamber is 1.1cc smaller than any of the PR3's. Some people don't like that manifold but really all you have to do is remove the secondary butterflys to open it up more or if you want get a Skunk2. If you do end up using any of the newer heads 92+ you'll have to swap the distributor to a non OBD one cuz it fires at a different rate than an OBD1 or OBD2, as for the injectors you can use your stock ones or any of the Jspec first Gen B16's....
josh_db1
Nov 23, 2009 06:59 AM
JDMbiAtcH
Aug 25, 2005 12:00 PM
Nickyj1211
Nov 7, 2004 11:21 AM
flyrice
Nov 22, 2003 09:37 PM
92TurboLS
Nov 12, 2002 10:14 PM
