is the this tube an inlet or outlet?
Old Sep 9, 2002 | 05:33 AM
_Endless_'s Avatar
Default is the this tube an inlet or outlet?
on the b16a of a 99 SiR, there's 2 steel tubes between the valve cover and t/b. one tube goes from the valve cover to the intake tract while the other steel tube is attached to the tube going to the intake tract but goes to the throttle body. from what i know the other steel tube carries the coolant(correct me if i'm wrong) to the throttle body, so my question is, is that line a coolant inlet to the t/b or a coolant outlet from the t/b?
Old Sep 9, 2002 | 07:44 AM
WOTTEG's Avatar
Default Re: is the this tube an inlet or outlet? (_Endless_)
Good question, replace a section of the tubing with clear hose, and watch the flow.
Old Sep 9, 2002 | 07:53 AM
Chris83179's Avatar
Default Re: is the this tube an inlet or outlet? (WOTTEG)
uuuuuum, that line goes to the throttle body for warmth in the winter, it would be an inlet, but i don't believe there is another line for "outlet", so, I dunno what you'd call it...
Old Sep 9, 2002 | 08:32 AM
WOTTEG's Avatar
Default Re: is the this tube an inlet or outlet? (Chris83179)
This system is connected to the IACV, which has the other end of the coolant flow.
Old Sep 9, 2002 | 06:28 PM
_Endless_'s Avatar
thanks. anymore???
Old Sep 9, 2002 | 06:51 PM
B18EG6's Avatar
i think hes got it!
g_steelo99
Aug 5, 2012 07:23 PM
ShinotakuX
May 14, 2008 09:55 PM
NSfit
May 3, 2007 05:11 PM
sldcivic
Jan 18, 2006 09:14 AM
EF8IGHT
Nov 8, 2005 07:53 AM
