how to find code from check engine light
Old Sep 11, 2002 | 04:55 AM
TheOne's Avatar
Default how to find code from check engine light
Can anyone explain how to check the code from a check engine light.
Old Sep 11, 2002 | 05:47 AM
94gsr's Avatar
Default Re: how to find code from check engine light (TheOne)
You have to short the service connector, then turn the key forward & the MIL will blink a number of times. If you don't know where the service connector is, a search will turn up the location for you. If you don't have a manual, post the code once you pull it & someone will tell you what it's for.
Old Sep 11, 2002 | 06:34 AM
jack25racing's Avatar
Default Re: how to find code from check engine light (94gsr)
http://tech.hybridgarage.com/tech/codes.html
Old Sep 11, 2002 | 09:22 AM
Katman's Avatar
I'm planning to revamp this page with better clearer pics, but it pretty much explains how to check what code is being thrown when you get a check engine light in a 92+ civic/integra.
http://tiiite.ghettoracer.com/autoP30.htm
Old Sep 12, 2002 | 09:44 AM
TheOne's Avatar
Default Re: how to find code from check engine light (Katman)
I found the code, its 14
can anybody tell me what it is?
Old Sep 12, 2002 | 10:47 AM
NiiS's Avatar
IAC
Old Sep 12, 2002 | 01:24 PM
TheOne's Avatar
Default Re: how to find code from check engine light (sinister)
I have a b16 head, and I tried to take the iac valve from my gsr head and put it on my engine, and the check engine light went away but my engine started making a real bad popping noise. So I put the old one on and the noise went away but the check engine light is on again. Does anybody have any suggestions on what to look for. My mechanic said to look for a vacuum leak, but I can't find any. This happened last night after I had driven my car for about 30. Now it comes on right away.
Old Sep 12, 2002 | 02:36 PM
2000blacksi's Avatar
New User
im pretty sure if you had a vacuum leak your idle would be going nutz.. like rising and falling rapidly non stop. my friends integra had a vacuum leak and it did this and we found one of the hoses was loose. we tightened it back on and it went away instantly .. im not entirely sure about this but im allmost positive.
Old Sep 12, 2002 | 04:22 PM
TheOne's Avatar
Default Re: how to find code from check engine light (2000blacksi)
my idle is just really low, its not jumping up and down now.
Old Sep 12, 2002 | 04:23 PM
TheOne's Avatar
I cant find a vacuum leak anywhere, I have no clue what it could be. any help would be appreciated from someone who has had this problem before or maybe from someone who had this code thrown on their car.
Old Sep 15, 2002 | 02:52 PM
RockDawg_GSR's Avatar
idle air control valve! Maybe its defective or unplugged or something.Play with it and try 2 erase the code and see if it comes back. You can do that by using a scan tool or simply by unhooking your car battery for a efw minutes then hooking it back up.
Climbtrees
Jul 26, 2012 01:32 PM
egsauce
Aug 17, 2005 09:39 PM
importdude2000
Jul 17, 2004 12:53 PM
