nitrous problem...backfire
Old Sep 10, 2002 | 06:01 PM
whatVTEC's Avatar
Default nitrous problem...backfire
here's my problem....i have a 93 hatch with a B18b, fully built. i'm running a 150 shot direct port NX kit. well when they tried to tune it, it backfired right away and then they didn't **** with it anymore. i have no bottle heater so i've been told that it could be too much fuel and not enough nitrous. i have a fuel pump,regulator and all that good stuff. any info will help. thanks. please email me if you can help me.
ESRlsHB@aol.com
Old Sep 10, 2002 | 11:58 PM
sweet's Avatar
Default Re: nitrous problem...backfire (whatVTEC)
have you inspected the motor?
have you checked the plugs, ignition system and fuel system?
by reading the plugs you can figure out alot. lean or rich. detonation.
what was your fuel pressure and your bottle pressure at the time of tuning?
what kind of fuel pump, FPR and ignition system do you have?
what's your ignition retard at?
do you have at least 2 steps colder plugs for a 150 shot?
more info will help and checking the plugs is very worth your time.
Old Sep 11, 2002 | 09:24 AM
martini's Avatar
Default Re: nitrous problem...backfire (sweet)
I agree, check the plugs.
but if it backfired, that means its probably rich.
why did they stop tuning when it backfired?
Old Sep 11, 2002 | 09:25 AM
Kataku2K3's Avatar
Default Re: nitrous problem...backfire (martini)
What are you running your ignition timing at?
Old Sep 11, 2002 | 12:07 PM
Mista Bone's Avatar
D Tranny Guru
simple, fuel puddling.
Start with a smaller shot and tune upwards.
No need for a heater as long as bottle pressure stays about 850-900 psi.
Old Sep 14, 2002 | 09:15 PM
whatVTEC's Avatar
i'm running colder plugs, MSD digital 6,6degree retard, and an aeromotive FPR and walboro pump. nitrous pressure was well under 800 don't know for sure cause i wasn't there during tuning.i also don't know where they put the fuel pressure. i was planning on changing my jets but i wanna get some input first cuz they're a bithch to change because all the plumbing is on the bottom of the manifold
Old Sep 15, 2002 | 11:06 AM
sweet's Avatar
what # plug do you have? fuel pressure may have been too high if you weren't there while it was being tuned. have you checked your plugs yet?
that sucks that the jets are underneath. my lines are on the sides so it only takes a minute or two to change them. going for a stealth setup?
later
Old Sep 15, 2002 | 06:06 PM
Weston's Avatar
I'm guessing it was just a backfire out of the exhaust. That can indicate a rich fuel mixture. If it backfires through the intake, then it's most likely running pretty lean. I saw a Mustang blow up pretty bad like that after he hit his Nitrous on the dyno.
95greenlude
May 2, 2007 02:02 PM
adamrich33
Feb 8, 2007 02:06 PM
BLU BY U
Honda Civic (2006 - 2015)
Nov 6, 2006 03:50 PM
PowerSpeed Motorsports
Jun 12, 2006 06:05 AM
blazin99si
Jan 3, 2006 12:13 AM
