VTEC switch??
Old Sep 10, 2002 | 03:35 PM
Mires's Avatar
Default VTEC switch??
Has anybody hooked their vtec up to a switch so u could turn it on when u want? I have had a few friends who have done this to their cars that they swapped the engines in. To me it doesn't sound like a good idea. Dont u lose power that way? If anybody has a answer to this it would be appreciated. I need something to prove to them that this isnt a good idea. Thanx for your help.
Old Sep 10, 2002 | 06:58 PM
Malice's Avatar
New User
Default Re: VTEC switch?? (ITR-862)
my friend knew someone that wired it to the horn. crazy!
Old Sep 10, 2002 | 07:05 PM
gsrvx's Avatar
New User
Just wondering...what is the point of making that switch?
-Rod
Old Sep 10, 2002 | 08:30 PM
Nameless RB26's Avatar
Default Re: VTEC switch?? (RK)
Here is a little something your friend should read:
"With add on VTEC controllers, the camshaft is forced to switch while running on the wrong fueling and ignition tables. This can cause fuel to be as far as 10% out and ignition to be retarded up to 6 degrees. Some VTEC controllers allow a coarse correction for fuelling, none allow correction for ignition advance."
Hondata.com
Old Sep 10, 2002 | 09:35 PM
MikeSarr_GSR's Avatar
Default Re: VTEC switch?? (Nameless)
USELESS HASSLE
Old Sep 11, 2002 | 09:40 AM
Kataku2K3's Avatar
Default Re: VTEC switch?? (MikeSarr_GSR)
Don't do it, if you wanna adjust your VTEC for tuning just get a VTEC controller, Nameless and MikeSarr_GSR are right. Why do it anyway, with a relatively stock motor switch if you switch it over too early you lose power, too high and you lose power.
Old Sep 11, 2002 | 09:47 AM
Kamin's Avatar
Default Re: VTEC switch?? (JDMspecEG6)
BuT ThEn I CoUlD Be In VtEcK AlL THe TiMe!
its pointless and a waste of time.
honda put the vtec engagment where it is for a reason. dont play with it unless you need to (cams, etc)
Old Sep 11, 2002 | 12:51 PM
Mires's Avatar
Default Re: VTEC switch?? (KAMiN)
I kind of understand what my friend is talking about. The way he sees it is when vtec is on it makes the best power so why dont he just turn it on earlier.
Old Sep 11, 2002 | 01:16 PM
builthatch's Avatar
MiG-21 superfan
oi!
Old Sep 11, 2002 | 01:42 PM
X2BOARD's Avatar
Default Re: VTEC switch?? (builthatch)
I kind of understand what my friend is talking about. The way he sees it is when vtec is on it makes the best power so why dont he just turn it on earlier. oi!
You don't want this, Honda put many years of R&D into vtec, the ECU knows the best time and conditions to engage it and has the fuel and igntion maps to support it properly... just leave well enough alone.
X2
Old Sep 11, 2002 | 02:50 PM
Quick 200k Mile Motor's Avatar
contrary to the hype, earlier is not better (in most cases).
Stock or Modified, most of the time the whole reason of being able to change vtec pt. ..is to move it higher.
It's best to let the ECU control it.
ECU gathers signals on vehicle speed, engine rpm, load, water temp, and other data to control VTEC.
VTEC is variable. For example, at optimum load, VTEC can come on at 5200, and if youre not really on the pedal.. it can come in at 4800. It might be the other way around, I dunno
The point is, let the ECU control it, or get Hondata. With Honderdata, VTEC will still vary even though you have a set point. Im not sure if VTEC will vary with a V-AFC, can someone comment on that??
Old Sep 11, 2002 | 03:21 PM
SquidwardTentacles's Avatar
Default Re: VTEC switch?? (Quick 200k Mile Motor)
the vtec lobes do not make more power at lower rpm. the whole reason for vtec is so u can a high reving car the makes lots of power up at the top of the rpm range while being driveable at the lower end.
unless ur tuning it on a dyno just dont change it.
Old Sep 11, 2002 | 03:57 PM
tinkerbell's Avatar
no you dont understand.
if you stop to think about it - both you and your friend will realise what it is you ar dealing with.
the reason variable duration and lift helps is becasue it allows you to utilise a HELLA lumpy cam profile that doenst work at low RPMs.
once into higher revs, the benifits of such a aggressive cam can be realised.
so yeah. VTEC doesnt make power - it is not a turbo - it only allows better breathing at higher RPMs.
that is all.
t..
Old Sep 12, 2002 | 08:03 PM
zeroracerh's Avatar
Default Re: VTEC switch?? (tinkerbell)
VTEC switch is bad!!!!
Old Sep 13, 2002 | 06:01 AM
CivicEx95's Avatar
VTEC engaging at low rpm = too much overlap = loss of power
chico1784
Oct 27, 2009 11:25 PM
philkehn
10
Oct 3, 2006 11:55 AM
Tatakai
14
Oct 7, 2005 07:03 PM
green91
17
Dec 29, 2004 03:27 PM
eg6madness
Mar 5, 2003 07:52 AM
