Mild rebuild advice
Old Mar 5, 2012 | 06:00 AM
FAITHhasME's Avatar
Default Mild rebuild advice
Well Im doing a mild b20b rebuild (b20z pistons and cams)
Really only questions is the piston removal, head is already off. Pop off the rod caps and up through the top right? Cant feel any sort of ridge on the top of the cylinder (low mile jdm b20b) and still has original hone marks. Im basically just switching pistons and new rings.
Thanks
Old Mar 5, 2012 | 06:08 AM
fcm's Avatar
fcm
Old Fart
Default Re: Mild rebuild advice
Yes, out the top, carefull, do not let the rods "bang around" in the cylinders. 94
Old Mar 5, 2012 | 10:58 AM
FAITHhasME's Avatar
got it, thanks
Old Mar 5, 2012 | 06:04 PM
talonboy1991's Avatar
indeed, you go through the top. in my haynes manual it reccomended to use some rubber hose over the rod bolts so you dont scratch the cylander walls. i thought it was a good idea and thought id share. i would also reccomend honing the cylanders so the new rings will seat
Old Mar 14, 2012 | 02:40 AM
Dioxine's Avatar
I never put new rings in without crosshoning
PINKFIFFTY
Jan 25, 2015 07:01 PM
Christopherian1982
10
Jan 22, 2009 11:00 PM
Hardedge
Oct 2, 2007 03:20 AM
b18ek670
May 2, 2006 04:54 PM
Boltz
Sep 17, 2004 07:30 PM
