cluster help my speed at zero
Old Feb 28, 2012 | 01:20 PM
Aylem1's Avatar
Default cluster help my speed at zero
well in the cluster where it says your speed move the needle stays at zero this happened after my ecu got messed up and my car went into limp mode and my civic wouldnt go pass 3500 rpm so i bought another ecu pr4 obd1 and it worked i just gotta reprogram it but the needle is still at zero as im driving i bought a new speed sensor because obviously i thought it was that i tested it and nutin so im basically stuck idk what it is that could be causing that..help guys
Old Feb 28, 2012 | 09:18 PM
grumblemarc's Avatar
The Grumpiest
Default Re: cluster help my speed at zero
Broken speedo.
Old Feb 29, 2012 | 07:01 AM
turbohatch96y7's Avatar
Have you. Put a multmeter on the wiring.
There should be 12v to one wire
Aa ground to the blk wire
And with the car jacked up spin the tire and measure the voltage on the last wire.
I can't remember the colors and since you gave barley any description of the year and harness you have I couldn't tell you.
Lazysk8r2
Feb 19, 2012 06:51 AM
afterdark
13
Apr 30, 2009 10:12 AM
Turbo Dan
20
Aug 5, 2008 09:46 PM
civickid03
Jul 20, 2006 06:03 PM
EF8IGHT
Feb 14, 2006 09:11 AM
