Quick question about....
Old Apr 16, 2012 | 09:15 PM
cryingsuns's Avatar
Default Quick question about....
....I was putting on my valve cover today but before I did I had to replace a stud bolt on my cam cover, (b18c1)the #4 bolt. I only torqued it to 12 ft. lbs when it should be 20 ft lbs. What should I do? Take the valve cover off and torque it to spec or will I be fine as is. I just changed my valve cover gasket..arghh..so if I take off my valve cover I'll have to get a new one...bleh. what would you do?
Old Apr 16, 2012 | 09:27 PM
doood's Avatar
been there done that
Default Re: Quick question about....
retorque it. you dont have to replace the vc gasket everytime you take it off, especially if it's brand new.
Old Apr 16, 2012 | 09:37 PM
cryingsuns's Avatar
Great. Thanks..So I just take off the valve cover, torque the bolt, remove all the hondabond on the head, add more, then re-seal and I'm good?
Old Apr 16, 2012 | 09:43 PM
JustOneOrTwoPosts's Avatar
yes. make sure you remove all the old stuff and the gasket and sealing area is clean and dry!
Old Apr 16, 2012 | 09:58 PM
doood's Avatar
i've had my vc off 4 or 5 times and never used hondabond. no leaks. i know it's recommended but i've never done it.
Slowbro98EX
Engine Machining & Assembly
Mar 12, 2017 09:12 PM
JJT211
20
Apr 19, 2013 02:14 PM
czsmola
Apr 25, 2010 05:38 PM
JDM_lover03
10
Oct 19, 2004 07:06 PM
honda lover
Jul 12, 2004 08:37 PM
